03-06-2012, 07:42 PM   #1
brosen's Avatar
How to Reset the File Name to 100-0001
I've changing the SD card and by accident I installed a card that was used with another camera and did not format it first before using it within the K-5, and now my file name is 100-0873 instead of being 100-0009, how can I reset the File Name to 100-0001, thanks a lot
03-06-2012, 08:43 PM   #2
aleonx3's Avatar
QuoteOriginally posted by brosen Quote
You just take your SD card out from the camera and put it in your computer. Then you go to the folder name (under DCIM main folder) corresponding the 100_0306 (note: 0306 corresponding to today's date) to move all the JPG or RAW image files except one (have to leave one there). Next, change the last image file to correspond with the last count. In your case, change the file name from IMGP0873 to IMGP0008.
Put the SD card back to the camera, and start shooting, the new image file will start at IMGP0009, IMGP0010 and so on.
03-06-2012, 09:35 PM   #3
I'm Still not able to change the file number
One note to add to Aleonx3's solution. It will only work if you go to menu page 5 > Memory then uncheck the "File No" item (the last one in the list on the 2nd screen). If it is checkmarked then the camera will still retain the last file no. even if you renamed ithe one remaining file on the SD card.
I had followed Aleonx3's steps perfectly but still couldn't reset the flie name. I finally figured out that I had to uncheck that one memory item.
03-07-2012, 12:28 AM   #4
Verglace's Avatar
I can verify that the above steps do work as I've done it before myself.
03-07-2012, 01:29 AM   #5
Banned
You just click al the way to 100-9999 and the next one wil be 100-0001 again.
camera, card, dslr, file, file name, k-5, k-5 ii, k-5 iis, k5, name, pentax k-5, reset
cant get film to reset Dlt Visitors' Center 3 10-08-2011 08:33 AM
k-x factory reset jolepp Pentax DSLR Discussion 17 12-16-2010 05:24 PM
K-X Setting reset static? NecroticSoldier Pentax DSLR Discussion 2 12-14-2010 01:28 PM
Notifications reset. Adam Site Suggestions and Help 4 11-02-2010 08:15 PM
I'd like to reset file modified stamp to that of picture taken Arpe Digital Processing, Software, and Printing 8 08-03-2008 06:35 PM
All times are GMT -7. The time now is 11:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
