03-16-2012, 05:20 PM   #1
eccs19's Avatar
Stumped
OK this one has me stumped. I've looked in the manual, but couldn't find it, or did find it, and just can't get it to work properly...
On my K7, when I preview a image I've taken, if I turned my camera 90 degrees, the image would rotate. I really like that feature, but for the life of me I can't figure out how to do this on my K5. I must be losing my mind. I hope they didn't take that option away.
03-16-2012, 05:30 PM   #2
aleonx3's Avatar
On the display menu (second tab), select and check mark "auto-image-rotation".
03-16-2012, 05:34 PM   #3
eccs19's Avatar
QuoteOriginally posted by aleonx3 Quote
It is checked, but no rotation. That was the one I figured should do it.
03-16-2012, 05:44 PM   #4
this may or may not answer your question...when you take a picture you will see a little green arrow at the bottom right...if you hit the flash arrow you will get an image rotation view and you can look at it at any angle you want...also if you set auto image rotation on the menu step 1 section it will automatically rotate vertical to horizontal...you can change the setting in menu back and it will rotate the picture back to original vertical...in all cases you can still access the roate key and change the view...hope this helps and i'm not confusing you more..amy
03-16-2012, 05:45 PM   #5
eaglem's Avatar
Not sure if this will help but you may notice green arrows either side of the check box and when going to either of these they put a tick in the check box, well un-tick the check box with the arrow key and re-tick the check box with the "Okay" button. Mine now rotates the image with rotation of the camera. Worth a try!
03-16-2012, 05:52 PM   #6
Col
Col's Avatar
QuoteOriginally posted by eccs19 Quote
The K-5 doesn't have that image review option. Only menus auto rotate with the camera. It was always thought that the first firmware update would reintroduce the feature... but it never has. The check box is to have the orientation saved in the image metadata for later display on PC etc.
03-16-2012, 06:27 PM   #7
eccs19's Avatar
QuoteOriginally posted by eaglem Quote
I had tried that, as I thought the same thing, but still no joy. Thanks for trying.
03-16-2012, 06:28 PM   #8
eccs19's Avatar
QuoteOriginally posted by Col Quote
You mean my K7 will do it, but not the K5? That's a real bummer. I really liked that feature.
03-16-2012, 06:45 PM   #9
Ex Finn.'s Avatar
That sums it up.
03-16-2012, 10:37 PM   #10
I'm not to sure if it's on the K5 but there is another setting to do with Rotation thats #33 Saving Rotation Info (Page 225 K7 manual)
camera, dslr, image, k-5, k-5 ii, k-5 iis, k5, pentax k-5, stumped
Nature Stumped mole Post Your Photos! 5 11-22-2011 07:08 PM
Whoops pjthiel Pentax SLR Lens Discussion 3 06-18-2011 10:31 AM
Nature Stumped tessfully Photo Critique 5 03-10-2011 05:56 AM
hyperfocus question Shuttershane Pentax Medium Format 8 01-31-2011 02:27 PM
MacOSX, PRA3.51, K100D. Stumped. Fat Boab Digital Processing, Software, and Printing 7 03-23-2009 02:22 PM
All times are GMT -7. The time now is 05:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
