03-21-2012, 03:42 PM   #1
cpk's Avatar
HDR Settings
I'm starting to do some HDR photography, shooting in raw, with both the K-5 and K-7; and I'm finding the manual, at least the K-5 one, a bit murky as to the best settings. I want the mirror to lock up on the first shot and remain up for the entire sequence of shots. It should also rise and lock a few seconds before the first exposure to ensure a steady camera throughout the sequence. The camera would be mounted on a tripod. What settings will best accomplish this? My reading of the manual suggests that I cannot get the exact sequence of actions I want.
03-21-2012, 04:48 PM   #2
With my K20D, I can set a 2 second timer delay which causes mirror lockup. Mirror lockup happens and then the sequence should start after the pause. With my K200D that option does not exist, but still, I have never had a blurred photo in the sequence when I can't use mirror lockup. (With the K200D you have to press the shutter and hold it down for the entire sequence or take each photo in the sequence by pressing the shutter each time.)
It's probably easier with the K5, but check out the 2 second timer delay option. It's probably the key.
03-21-2012, 06:28 PM   #3
Enable one-push bracketing (Custom menu option #9)
Select bracketing drive mode, or bracketing with wireless remote (depending on whether you're using a wired or wireless shutter release.)
Compose/focus/etc.
Hit the LV button to lock the mirror up.
Wait as long as you'd like for the mirror to settle.
Hit your shutter release to take the pictures.
03-21-2012, 07:25 PM   #4
panoguy's Avatar
Yep, Live View does what you'd like. Here are another couple of helpful settings for shooting Raw brackets for HDR (as opposed to using the built-in HDR function, which is actually exposure fusion and produces a JPEG!) with your K-5:
Custom setting #8 -Auto Bracketing Order, set to "2" so your fastest shutter speeds go first, which will reduce the chance of ghosts between exposures.
E-Dial Programming, set "M" (manual) mode "Green Button" function to TvShift. No idea why, but this green button setting also controls how your Auto-Exposure Bracketing will get the different exposures when set in that mode. (In this case, only varying the shutter speed - if you leave it unset or choose AvShift, it will (also) vary your aperture, screwing with your DOF!)
03-22-2012, 12:23 PM   #5
cpk
cpk's Avatar
Thanks, all, for your responses. I just ran some tests on my K-7 with both the remote control and cable switch. Both worked like a charm. I never knew that about Live View, that the mirror is locked up; nor does the manual seem to indicate it as a way to accomplish this. I don't use Live View because I wear variable-focus glasses and craning backwards to see the screen hurts my neck.
camera, dslr, hdr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, sequence, settings
HDR, Megapixels, and Software PaulfromTexas Digital Processing, Software, and Printing 10 02-21-2011 08:13 AM
Misc Forrays into HDR einstrigger Post Your Photos! 9 01-27-2011 12:27 PM
best bet for HDR Photos K-7, K-R, or K-X ? pixelhunter Troubleshooting and Beginner Help 13 01-03-2011 07:00 AM
HDR: Does the exposure settings in the K7 make much of a difference compared to K20D? Lulerfly Pentax DSLR Discussion 1 11-07-2010 09:25 AM
settings for K-7 Regalo Pentax DSLR Discussion 3 04-26-2010 03:09 PM
All times are GMT -7. The time now is 08:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
