03-27-2012, 11:32 PM - 1 Like   #1
bwDraco's Avatar
New K-5 first impressions
I just got my new K-5 from B&H, and I've been playing with it for the last few hours. In no particular order, here are my first impressions:
  • Coming from a K-r, the large grip of the K-5 felt somewhat uncomfortable. Given that cameras like the Canon EOS 7D and Nikon D300S have similarly large grips, it's something I should--and will--get used to.
  • The LCD has one pixel stuck green. I suppose that this is an isolated case, and I will accept this as within manufacturing tolerances. However, when the K-5 is serviced for the first time (which may be in the far future), I will make note of the stuck pixel.
  • The in-body AF motor runs slower than that of the K-r. This slightly reduces AF performance, but the K-5 has better AF accuracy because of the light wavelength sensor and the AF isn't quite as noisy.
  • The control layout needs some time to get used to, but it'll probably permit more efficient operation once I do. Some of the levers seem stiff, but they'll probably loosen up with use.
  • The battery shipped low (but not so low that the camera could not be operated). The battery also takes a long time to charge (the manual states a maximum of 390 minutes, or 6 1/2 hours) and is much larger than that of the K-r. The battery is still charging as I type this.
  • The K-5 shipped with firmware 1.01. I charged the battery for some time, then proceeded to upgrade to 1.13 without issues.
  • The shutter is significantly quieter than that of the K-r. The shutter recock noise is quite apparent, but overall operating noise is certainly less than that of the K-r.
  • The sensor was clean and had no dust or stains.
  • The Dust Reduction II mechanism in the K-5 is much quieter and is considered to be more effective than the SR-based DR in the K-r. Furthermore, the automatic DR II on power on can be interrupted (unlike the K-r), so that having it on does not slow the power-on-to-first-shot time.
  • The shutter count started at 1, indicating that the camera was brand new and not returned by another customer.
  • Several benefits are realized from the K-5 having independent shutter, mirror, and aperture control motors. This includes depth-of-field preview without the need for the mirror to cycle, continuous depth-of-field preview before shooting a video, and better mirror lock-up support.
  • The flash is popped fully mechanically, rather than electronically (by means of a solenoid moving a hook) as on the K-r.
  • Being able to manually override the auto-ISO and resetting to auto-ISO without entering the menus is a real boon, saving quite a bit of time.
  • The way the battery cover opens is entirely unlike that of the K-r and is similar to the design used in professional Canon and Nikon DSLRs: turn a lock and pull out. I suppose this is needed to achieve full environmental sealing...
  • A test of burst shooting in manual mode, 1/8000s, f/2.8, ISO 80, MF showed that the camera was physically capable of attaining a full 7.0 fps, but more practical speeds are about 6 to 6.5 fps.
  • I found the horizon correction to be really helpful, and it certainly did a very good job at making sure the horizon is level.
  • The viewfinder is larger and somewhat brighter than that of the K-r owing to the 100% coverage pentaprism design. The numbers on the data line are larger and easier to view as well.
  • Per-pixel noise doesn't seem to be that much better than that of the K-r, but since the pixel count is higher, the K-5 will outresolve the K-r at all ISO levels.
  • The User modes let me switch quickly to a particular configuration when the situation demands it, which can help me get faster shots.
That pretty much sums it up. The K-5 is simply amazing, and I probably will appreciate it more as I shoot with it more. The "ceremonial first shot" is attached.
--DragonLord
PENTAX K-5  Photo
03-28-2012, 12:15 AM   #2
snappychappy's Avatar
It is rather good isn't it? enjoy.
03-28-2012, 12:20 AM   #3
philbaum's Avatar
Yes, i find it amazing as well. Good review!
03-28-2012, 12:54 AM   #4
wizofoz's Avatar
Its a great camera, but I can't get over the juxtaposition of 'dragonlord' and the fluffy bunny....
No offence meant, its just my sense of humour.
03-28-2012, 01:04 AM   #5
bwDraco's Avatar
QuoteOriginally posted by wizofoz Quote
...I can't get over the juxtaposition of 'dragonlord' and the fluffy bunny....
Yeah, it is kinda funny...
--DragonLord
03-28-2012, 02:00 AM   #6
Kiwi Pentaxian
NZ_Ross's Avatar
DragonLord - I am pleased you brought a K-5. I am sure you will enjoy. I know I am - and I am very happy with its performance in low light with the 16-50 mounted.
Cheers
Ross
03-28-2012, 12:57 PM   #7
Jean Poitiers's Avatar
K-r => K-5
Bonjour DragonLord,
Glad you like it ... and I still have not yet compared the AF speeds between he two bodies.
Salut, J Frog
03-28-2012, 04:58 PM - 1 Like   #8
Col
Col's Avatar
Perfectly understandable mix IMHO
03-28-2012, 05:36 PM   #9
bwDraco's Avatar
QuoteOriginally posted by Col Quote
--DragonLord
03-28-2012, 10:24 PM   #10
abmj's Avatar
"Right! I'll make rabbit stew out of 'im. .. Aarrgh!"
"Bring out the Holy Hand Grenade of Antioch!"
03-28-2012, 11:02 PM   #11
mrjamesabels's Avatar
At iso 80 the dynamic range is amazing! You will love it.
battery, camera, dslr, k-5, k-5 ii, k-5 iis, k5, mirror, noise, pentax k-5, shutter, time
First Impressions of my new K-5 Docrwm Pentax K-5 22 12-04-2011 09:28 AM
FA*28-70 - first impressions axl Pentax SLR Lens Discussion 29 10-12-2011 05:28 AM
K5 first impressions an3ony Pentax K-5 8 08-29-2011 12:10 PM
My impressions of the K-r deadwolfbones Pentax K-r 14 03-02-2011 02:02 PM
My K-5 First Impressions deadwolfbones Pentax K-5 53 10-29-2010 07:31 PM
All times are GMT -7. The time now is 02:34 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
