Originally posted by jase036
The servo mode in Metz flashes is indeed just a dumb slave mode set to ignore preflash, you can test this out by grabbing any other flash, setting it to the lowest power and firing off 2 flashes in quick succesion, the metz in servo mode will fire along with the second flash (I tried this with a Vivitar HV285), which means it will sync with any other camera or flash system that uses pre-flash for metering, it works very well with the onboard set to regular flash (more proof that the Metz in servo mode does not use or require Pentax's wireless P-TTL specification).
I was able to get the onboard flash to sync with the Metz in servo mode using the onboard as controller which I thought was pretty cool, but since I normally use radio triggers with the flashes on manual control it seems pretty moot to want to use optical sync with manual flash control (seeing as how I get better range and reliabilty using radio).
Ok, had a weekend to play. The servo mode
requires the pre-flash to trigger, although it can be any pre-flash. I used an ancient flash (film days one) to try to act as the trigger with no joy as the trigger flash had no pre-flash. However, a friend using his Canon 7D pop up triggered the Metz very well (he ended up using my Pentax-Metz behind an umbrella as well as his Canon flash wirelessly to great effect at my daughter's 21st).
Well I learnt something new about my flash - thanks.
