04-02-2012, 01:21 AM   #1
M lens use
I have a Pentax M lens 135mm which I want to use on my new P5...........30o page instrustion book take time to work through [and full of techie langauge] and many things are beyond me!!
What setting do I need to use the lens on manual focus - I can use the lens but I have to use my old eyes to get focus correct - I have not been able to set so the it bleeps when focus is correct.
Any help would be appricated.
Martin
04-02-2012, 02:02 AM   #2
QuoteOriginally posted by thegrasshopper Quote
The P5 won't beep because it's a manual focus camera. What you can do, though, is take advantage of the split-screen focusing screen (I believe it has one) to verify that the image is in focus, and get a diopter appropriate for your eyes.
Once you get that taken care of, the lens should be quite easy to use in Av or M mode
04-02-2012, 02:25 AM   #3
dosdan's Avatar
Set C.27 (on menu page C4) to: 2 - Permitted.
On the Set-up (spanner) menu page 1 ensure that the Beep volume is turned up. If set to 0, the beep is turned off. See p.288 of the manual. When adjusting this volume ensure there is a tick in at least the first of the following beep selection boxes below it:
In-focus
AE-L
Self-timer
Remote Control
Mirror Up
LV is great for static MF use. See:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/168950-super-t...ml#post1751554
https://www.pentaxforums.com/forums/pentax-k-5-forum/167780-using-m-lens-lv-k-5-a.html
Dan
04-02-2012, 06:37 AM   #4
aurele's Avatar
thegrasshoper is talking about the P5 also known as the P50, which was created in 1986 and sold until 1989.
You got it, it's not a typo
04-02-2012, 06:55 AM   #5
boriscleto's Avatar
QuoteOriginally posted by aurele Quote
Then why is it in the K-5 forum? I also rather doubt that the P5 had a 300 page instruction manual. The manuals in those days were only about 60-70 pages. Using a M lens on the P5 wouldn't have been a problem at all. It only would have worked in Aperture Priority mode or Metered Manual mode.
camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5
Keep K-x buy premium lens, get K-r and get good lens, get the K-7 w/ lens or K-5? crossover37 Pentax DSLR Discussion 19 02-06-2011 10:38 PM
All times are GMT -7. The time now is 06:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
