On multiple occasions I have found a substance that appears on my grip and k-5 following use around a swimming pool. The substance appears to be a white residue, perhaps similar to what can be found on the battery terminals of a car. I shoot a lot of swimming competitions and my camera does get splashed a times, but not at a level that I would consider to be significant. The substance appears in the same location each time, centered around a screw on the grip. There is some blackness in the substance as well, almost appearing as carbon from sparks. As seen in the photos, the substance appears on both the camera and the grip. The substance is easily cleaned off. To me it looks like some kind of a short circuit due to the presence of pool water between the surfaces. However, I've not seen any functional problems when this has happened. I've not had any malfunctions and my battery life seems fine. The pictures don't clearly show the blackness that appears to be from some type of spark or short circuit. The substance and pattern appear consistently when this occurs. I'm interested in theories regarding the source, potential outcome and possible remedies for this problem.
