04-03-2012, 06:32 PM   #1
Multiplier for natural resolution on K-5 display
If I wanted to try and check the sharpness of a shot on the camera display, what would the most accurate magnification level to use. Since the K-5 has a resolution of about 16 megapixels and the display is about 1 megapixel would a magnification of 4x be most accurate, or am I missing something? Any insight would be appreciated.
Mike
04-03-2012, 06:42 PM   #2
About 8x is full size, I believe.
04-04-2012, 05:02 AM   #3
jeffshaddix's Avatar
I think 4x is right, that's a linear factor. At 4x you can view 1/16th of the image at a time.
I use quick zoom 4x to test focus on shots, quite a handy feature!
04-04-2012, 08:11 AM   #4
I've always used 8x and it looks correct to me.
04-04-2012, 11:19 AM   #5
Adam, Jeff, Deadwolfbones,
Thanks all for taking the time to reply. Examing some pictures really close in the daylight (my eyes don't work as well in the artificial light after the sun goes down as they used to) I've come to the conclusion that 4x is correct, but the display seems to do a really fine job of smoothing out the greater magnification. That being the case, I'm not really sure whether the display helps very much towards determining full-sized sharpness. Not exactly the same thing, but sort of like looking at a 4x6 to determine whether it's going to look nice at 13x19.
Thanks again,
Mike
04-04-2012, 11:26 AM   #6
maltfalc's Avatar
the k-5's lcd is nowhere near 1MP. it's 640X480.
04-04-2012, 11:43 AM   #7
Banned
QuoteOriginally posted by maltfalc Quote
If it only was better. QHD would be great for the nect.
At 8x you are pixelpeeping. At 4x you should be able to see some descent performing to judge.
04-04-2012, 11:44 AM   #8
Matfalc,
Thanks for the reply. 640x480 equals 307,200 dots, and the K-5 owners manual says the resolution is approximately 921,000 dots. I believe a megapixel is defined 1,000,000 so I considered that close enough to round it up.
Mike
04-04-2012, 12:01 PM   #9
Ron,
I'm new to Internet forums and don't understand.
True, I am pixel peeping as my hands aren't extremely steady (even with shake reduction), and if I'm in a situation where I want a crisp shot for a large printout, a means of assurance that I nailed it would have been nice.
Mike
04-04-2012, 01:03 PM   #10
Banned
QuoteOriginally posted by MikeR Quote
Matfalc,
Mike
These are pixels and times 3 (a dot for Red, Green and Blue) makes 640x480x3=921600 dots (yes they fool us).
Ron,
Mike
QHD is a quarter HD so a larger screen with 960x540x3=1.55miljon dots. For a next generation with a larger 16:9 screen.
I do the pixelpeeping as well, when sharpness is crucial.
04-04-2012, 01:48 PM   #11
I remember reading in one of my manuals (can't remember if K-x or K20D) that previewing at 11x was 100% resolution. My guess is that the K-5 manual will also disclose that information.
04-04-2012, 03:04 PM   #12
Ron,
I was unaware of that, but that makes what I have been seeing and what everyone has been saying, gel and make perfect sense. 307,200 dots with it being linear would be about 8x and that would explain why I convinced myself "the display seems to do a really fine job of smoothing out" the 8x magnification. The little bit of what I was thought might be noise was probably just greater detail, or a combo of the two. I sort of feel like a doofus, but question is answered, I understand why, and problem solved!
Thank you everyone,
Mike
04-04-2012, 03:10 PM   #13
maltfalc's Avatar
the long edge of the image reduced to fit the lcd (640 pixels) is considered 1X. 640 x 7.7 = 4928 pixels (the long edge at full resolution).
04-04-2012, 06:08 PM   #14
QuoteOriginally posted by RonHendriks1966 Quote
That's sneaky!! Bah, 8x it is then!
04-08-2012, 08:05 AM   #15
cbope's Avatar
QuoteOriginally posted by jeffshaddix Quote
It's not sneaky. A dot is NOT a pixel. A pixel is made up of 3 colored dots also known as an RGB triad (red, green, blue). Dots are also sometimes called sub-pixels.
Now, if Pentax had said 921k pixels, and the display is 640 x 480 pixels in height and width... then some sneakiness (or more likely, dumb marketing types) may be involved.
camera, display, dslr, k-5, k-5 ii, k-5 iis, k5, magnification, pentax k-5, resolution
Image Resolution for Display calicojack Troubleshooting and Beginner Help 9 10-25-2009 11:21 AM
For Sale - Sold: [CLOSED] [EU] Vivitar (Kiron) 3.8/75-205mm + 2X Matched Multiplier ovim Sold Items 6 08-21-2009 04:11 AM
For Sale - Sold: Vivitar 75-205mm 1:3.5-4.5 with 2x matched multiplier duncsuss Sold Items 4 08-12-2009 06:44 AM
dslr focal length multiplier and lens hoods dmoon911 Pentax SLR Lens Discussion 3 07-30-2008 06:34 AM
conversion multiplier for digital designed lenses? slip Pentax SLR Lens Discussion 3 11-16-2006 01:28 PM
All times are GMT -7. The time now is 11:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
