04-06-2012, 02:56 AM   #1
K-5 AF.S / AF.C / MF switch defective?
Hi all,
I am new to this great forum and have recently bought a new K-5 with the DA 18-55 AL WR kit zoom.
I noticed that the AF.S / AF.C / MF switch does not have three firm positions, but only has a slight click/stop for each position. Because of this it is easy to put the switch in between the three positions when I have my eye to the viewfinder.
Is this how the switch should function or is the switch on my K-5 defective? I could not find the answer using the search function.
Thanks.
04-06-2012, 03:03 AM   #2
Verglace's Avatar
Yep, mine is like that as well. Although... it is kinda hard to switch for me so I can't see how it would get accidentally changed
04-06-2012, 04:53 AM   #3
Mine is the same. There is slight detent on each of the settings but it is not firm. One thing I did notice is that the detents seem to be more noticable going from AFS to AFC to M than they do going from M to AFC to AFS. However it isn't a big issue for me as I rarely shoot in AFC, so I usually just push the lever all the way up or all the way down.
NaCl(it is not a problem for me)H2O
04-06-2012, 02:16 PM   #4
Thanks for the reassurance. I do think that the switch is a bit flimsy regarding its use. However this does not seem to warrant returning the camera. I wonder if other members have a different experience.
04-06-2012, 04:31 PM   #5
It's the Pentax weather sealing effect I guess. If you use your index finger to change it---while shooting--- it's easy enough to feel the AFC position click in. AFS & MF are at the ends so no problem.
This switch does break in nicely if you help it ---Cycle it multiple times enough and it will improve---
04-06-2012, 04:35 PM   #6
Ex Finn.'s Avatar
The weather seals make it feel "mushy". Not sure why you would consider the lever flimsy, I have not heard of one breaking.
04-06-2012, 04:42 PM   #7
crewl1's Avatar
Same here. Hasn't caused any problem.
04-06-2012, 05:05 PM   #8
Mine is the same - I wouldn't describe that as "flimsy", it actually feels too firm to move if anything.
Regards,
David
af.c, af.s, camera, dslr, k-5, k-5 ii, k-5 iis, k5, mf, pentax k-5, positions, switch
Is my K-x defective? chef Pentax DSLR Discussion 9 03-07-2012 04:05 PM
Please Help ... Did I get a defective lens? stills999 Pentax SLR Lens Discussion 33 05-06-2011 12:29 PM
K-7 Defective Sensors? Loren E Pentax DSLR Discussion 16 12-11-2010 06:17 AM
Is My DA40 LTD Defective? jaieger Pentax SLR Lens Discussion 4 08-16-2010 08:14 PM
Defective meter on my new k7? pentup Pentax DSLR Discussion 11 07-04-2010 12:30 PM
All times are GMT -7. The time now is 06:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
