04-06-2012, 06:40 PM   #1
manual stop down problem
for some reason my hanimex 2x auto teleconverter wont stop down or fire at the correct aperature size. all it does is shoot wide open all the time. any ideas on what the problem is?
04-06-2012, 06:47 PM   #2
joe.penn's Avatar
QuoteOriginally posted by ckswong Quote
Pertaining to K-Mount Lenses
If you are in "Hyper Manual" mode and this is happening, you will need to short the contacts on the camera body with a piece of foil. The teleconverter probably has a painted flange, since it is painted there is no connection of any sort being made to the contacts on the body so the body is thinking you do not have a lens attached and won't activate the stop down linkage. The "grounding or shorting of the contacts" is a built in fall back to allow for older manual pentax k-mount lenses to be used...
04-06-2012, 06:53 PM   #3
i just put a piece of foil between the last to contacts closest to the red dot on the body and ALAS! it stops down, the screw is inset on the converter causing one of the contacts to not touch the mount. is there a way to fix this without foil?
04-06-2012, 07:35 PM   #4
With lenses and extension tubes that have a black painted/anodized mount, lightly sanding the part of it that sits over the contacts will do the trick. It exposes the bare metal and shorts the contacts. I use a fine silica sandpaper for this. It should be the same for TCs as long as it has a metal mount.
04-06-2012, 07:36 PM   #5
fixed it just now, i backed out the one screw that was not making contact till it was. i was thinking of puting a drop of solder on there but i was too lazy to fire up the iron. thanks.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Manual apature stop-down metering? Chonker Troubleshooting and Beginner Help 34 03-23-2011 01:23 PM
Cannot stop down manual lens for some reason SamWarrick Troubleshooting and Beginner Help 28 09-06-2010 10:21 AM
f stop input for manual lenses? axl Digital Processing, Software, and Printing 6 06-30-2010 05:09 AM
10 Stop ND Problem Graham V Photographic Technique 10 05-17-2010 09:02 AM
Macro: Handheld, Manual Focus, Manual Stop-Down Mike Cash Post Your Photos! 2 06-19-2008 07:14 AM
All times are GMT -7. The time now is 10:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
