Originally posted by JohnBee As can be seen, both files were shot in identical settings. That is to say that both were setup under the same lighting, with matching camera and lens settings(focus). However... to help make things as objective as possible, I've chosen a JPG sample yielding the most contrast and detail out of all of the camera profiles. However, if for any anyone should feel that the test would have been better conducted using another OOC candidate, then I would be more than happy to revise the sample.
#1 was shot at f./5.6 and 1/20th. #2 was shot at f./8 and 1/10th. I have to wonder if the DoF difference is causing a noticeable change in the results. It could affect sharpness slightly, too. Many lenses are at their sharpest at about f./8. The same settings should really have been used.
The other thing I wonder about is that the camera passes various jpeg defaults to the raw editor via EXIF, and depending on the raw editor used, some, all or none of these may be applied on opening the raw file. I haven't used RAW Therapee, so I don't know its behaviour on this front. It would fuzz the results quite a bit if some of the jpeg defaults were being applied.
