04-11-2012, 01:09 AM   #1
Etrsi_645's Avatar
Focus: mismatch between body & lens?
I don't understand why focusing parameters exist both on the lens and on the camera body. What if I want manual focus and change it in only one place and not the other? There can be several mismatch combinations between the body and lens. Is there a table telling me what the results are for such?
thx
04-11-2012, 01:24 AM   #2
It's for convenience, mostly, and also not all AF lenses have an AF/MF switch.
Another application is when using manual lenses. If you set the camera to AF.S, it won't fire until it thinks the image is in focus
04-11-2012, 07:23 AM   #3
What 'focus parameters for lenses' are you referring to?
04-11-2012, 08:53 AM   #4
Etrsi_645's Avatar
on my DA* lenses there is a switch for AF/M. On the camera body there is a switch AF.S/AF.C and MF. So does the body setting have to match the lens setting?
04-13-2012, 01:27 PM   #5
QuoteOriginally posted by Etrsi_645 Quote
No. But the setting on the body takes priority.
If the switch on the body is set to Manual Focus, the switch on the lens has no effect.
If the switch on the body is set to Auto focus, you can toggle back and forth quickly with the switch on the lens. It's just for convenience.
Most lenses don't have the switch on the lens, so usually you have to use the switch on the camera.
If that doesn't confuse you enough, ask someone about the quick-shift on the Limiteds.
(I would LOVE a digital ETRSi)
body, camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, lens, mismatch, pentax k-5
K-5 Manual Lens Front Focus & Focus Beep woes fixed kneonx Pentax K-5 14 04-12-2014 03:47 PM
Error Forum Home mismatch jheu02 Site Suggestions and Help 3 02-05-2012 02:58 PM
For Sale - Sold: (AUS) SMC Pentax-M 50mm/1.4 & A35-105mm/3.5 & MV1 body & DB1 Grip (AUS) ddhytz Sold Items 4 04-22-2010 03:28 AM
For Sale - Sold: 5 Asahi Pentax Super-Multi-Coated Takumars Lens & Spotmatic SP II Body / acces jubei951 Sold Items 6 04-29-2009 10:14 AM
For Sale - Sold: Pentax K200D Body & SMC DA 16-45mm Lens and AF540FGZ Flash & Canon 40D All Br walay Sold Items 11 07-29-2008 10:57 AM
All times are GMT -7. The time now is 10:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
