Originally posted by Philoslothical I'm not sure you've thought this through. The air pulled by the vacuum would have to come from somewhere. If you're blocking ingress around the camera's mount by using tubes and a hose, where do you think that airflow is coming from? On unsealed bodies, you'll get a bit through the seams and the viewfinder (potentially pulling dust onto the focusing screen), and you'll get some around the extension tubes, which won't help to clean in the mirror box at all. I think all this would accomplish is stressing the vacuum's motor.
If you are in a minimal dust environment like a clean bathroom, and you use a second or two burst of suction (remember, the rubber tube can also stretch) that might not be much of a problem, dust on my viewfinder and focus screen I can live with.
Another option would be to vacuum seal the camera and extension tube, just making a hole in the plastic for the air to be sucked out, that should prevent dust from entering from any other place in the camera. I'm thinking of using a small, low suction vacuum cleaner I got years ago to clean the inside of my car, or one of the blowers you get with inflatable mattresses, which you can use with a reverse flow to suck air out of the mattress?
Well I've been looking for an excuse to upgrade from my K-x to a K-5, so I might just as well give it a try, and if I end up with some camera parts in the vacuum bag, it might still be a good experiment in the end. If it works I'll have a nice clean K-x, if not a nice new k-5, seems like a win-win situation in my case.
