04-26-2012, 01:07 AM   #31
Lower-41's Avatar
RAW (dng, Adobe RGB) for all my shots, imported to Lightroom for tweaking to taste then exported as sRGB jpeg’s for screen viewing.
04-26-2012, 02:14 AM   #32
I've always used RAW in PEF / sRGB.
PEF takes a bit longer to import inside lightroom since it converts it to DNG, but it allows for more pictures per SD card since PEF has some lossless compression
04-27-2012, 12:30 AM   #33
Is it just me or does Reveral Film disable auto-WB? I know that's more "accurate" and I like the LCD-look of that setting but I don't want to have to manually WB every shot in post, normally the internal WB does a great job so I like having that reference.
I use Vibrant myself, but only shoot RAW so it only affects the LCD image, Vibrant makes people go "ooooooh" when they see super-sharp saturated pictures.
04-27-2012, 03:14 AM   #34
My default settings are RAW DNG, Adobe RGB, AUTO WB, Bright 'colormode', Exposure correction -0.3, Single AF&Shoot, Selected AF point, Multisegment Exposure metering
Sunny outside I use as default "level 1 shadow correction" (or something like that)
Mostly I do convert DNG->JPG (****,16mpx, ADOBE RGB) using K5 for printing, then use photoshop to generate smaller sRGB JPG files for internet or email use
If needed I edit DNG files for printing using Camera RAW and photoshop
04-27-2012, 02:50 PM   #35
QuoteOriginally posted by longview Quote
I just checked on my K-5 and you're right. AWB doesn't seem to correct very well for tungsten lighting
with reversal film. That's odd.
Regards,
--Anders.
04-29-2012, 04:27 PM   #36
I shoot DNG raw. However, I disagree that the image settings are "useless" if one shoots raw: the embedded jpg in the raw file is used as the in camera display. As a result the histogram comes from it. Thus, using the natural (even with lowered contrast a tad) gives you a much better idea of what information is actually available in the raw file. Using the "bright" setting clips either end of the histogram, and will make you think that you have clipping, when in fact in the raw file it isn't clipped.
Regards,
Dave
05-05-2012, 02:24 PM   #37
selar's Avatar
Does anybody use cross processing?
05-05-2012, 02:29 PM   #38
Crosshair's Avatar
I don't think so
05-05-2012, 03:48 PM   #39
I just shoot in RAW and use Adobe Lightroom for my workflow - I'm surprised to hear the advice that I should use sRGB. Surely AdobeRGB in the settings would be more suitable, given that this is an Adobe product?
05-06-2012, 06:39 AM   #40
QuoteOriginally posted by selar Quote
Sometimes. It's hit or miss but once in a while you get a pleasing result. This was preset no.2.
Cross processing works best when the toning aligns with the colours already in the image.
Regards,
--Anders.
05-07-2012, 05:29 AM   #41
QuoteOriginally posted by peteste Quote
It doesn't matter at all if you shoot raw. That setting is only for the out-of-camera jpg's. RAW doesn't have a color space. Lightroom, Photoshop and most (if not all) advanced raw developer / photo manipulator softwares use Prophoto RGB color space internally and export jpg's to sRGB by default.
05-07-2012, 05:39 PM   #42
selar's Avatar
QuoteOriginally posted by asp1880 Quote
Regards,
--Anders.
Thank you for your post. I remember seeing it elsewhere, perhaps dpreview, and that image is what provoked my curiosity in cross processing. Very tastefully done!
05-07-2012, 05:40 PM   #43
selar's Avatar
QuoteOriginally posted by simico Quote
True, the demosaicing algorithm used by your raw converter is more relevant.
camera, contrast, dslr, jpeg, k-5, k-5 ii, k-5 iis, k5, pentax k-5, saturation, settings, sharpness
People Which of the 3 would you prefer, if any? m8o Photo Critique 20 10-13-2010 07:51 PM
People Which One Do You Prefer? jaieger Post Your Photos! 7 09-16-2010 07:02 PM
DA 21 or DA 40, Which one do you prefer? Eagle_Friends Pentax SLR Lens Discussion 4 04-16-2010 04:57 PM
Monitor Settings & picture resolution Susan Pentax Compact Cameras 4 05-21-2009 08:26 AM
Noob Question. Knowing what settings you shot the picture. 68wSteve Photographic Technique 11 07-31-2008 09:50 AM
All times are GMT -7. The time now is 07:06 AM. | See also: NikonForums.com, part of our network of photo forums!
