04-17-2012, 11:05 AM   #16
It has to do with hardware memory: more and faster buffer memory is more expensive. Also compression must be taken into account for JPEG: most companies list their JPEG throughput for the highest compression and lowest quality.
At 7fps and around 24 RAW in the buffer before it has to flush to the card the K-5 seems fairly respectable to me.
04-17-2012, 08:43 PM   #17
Anvh's Avatar
ENicolas, you missed my comment before you.
RAM is the fastest piece of hardware in it and image processing and "flushing" are done at the same time by different processors.
The K5 use 2x DDR2 ram's just look up the minimum speed for those
found some hard data about speed indication.
the processor in the K10D/20D uses 750MB/s for his RAM in the K7 and K5 there is a newer processor.
buffer, camera, conditions, dslr, fps, jpeg, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shots
Would a better lens give me deeper DOF? reggieperrin Troubleshooting and Beginner Help 19 05-22-2011 08:44 PM
k-7 4 shot buffer? cwood Pentax DSLR Discussion 5 02-12-2011 10:18 PM
Larger buffer might actually be HW? Gimbal Pentax DSLR Discussion 38 11-02-2010 06:21 AM
K5 Buffer BrendanPK Pentax K-5 133 10-30-2010 01:09 AM
K-7 40 jpeg buffer enough? Pentaxor Pentax DSLR Discussion 5 06-28-2009 01:28 PM
All times are GMT -7. The time now is 09:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
