04-16-2012, 12:52 AM   #1
Things you want Pentax to improve on K5
To me, I have some and hope Pentax can improve in next firmware or camera:
- Mode dial button: the lock button is good to prevent from moving but can make it better: press down to lock, press it again to release lock
- Shoot button: the half press is too slight, I want it more feeling
- Delete button: you have to press once then press Up + OK to delete. Why don't press Delete twice to delete? (*)
- Timer shooting: allow customize the timer, currently, it is 2 secs, 12 secs only
- Instant review after shooting: must improve this to let it be faster. It's too slow, like an old man or normal dslr (*)
- Allow fast switching between modes (user 1, user 2, etc.) when in User Mode, no need to dig in Menu
- The metering mode button really hurts my finger
- Auto image rotation should be enable when reviewing photos, currently don't have this feature (*)
(*) High priority
>> Update from contributors <<
- Faster image processing
- The rear AF button should wake up the camera, not just the shutter button (that gets me all the time!)
- Electronic level user calibration
- No FF in artificial light
- Options for Zoom AF calibration
- Improve AF speed
- Improve vignetting correction
- More and smaller crossed AF points.
- 1080p and 720p video output to capture 60 to 100 fps with full manual control and full time AF.
- Dedicated video button.
- Better AF-C performance.
- Dual card slot.
- Take advantage of fast SD cards
- Improve RAW histogram
- Auto ISO mode: ability to set minimum shutter speed
- Possibility to save any of modes into User modes
- Add more video format
- More button function assignments
- Option to use the 2 second timer with mirror lock up
- Pop up flash would also nice to have manually adjustable power (like 1/1, 1/2, 1/4, 1/8 etc power)
- Separate joystick to select AF points
- HDR mode with raw format (able to post process)
- Allow turn off the zoom feature when focusing in Live View
- Manual calibration of the electronic level
04-16-2012, 12:57 AM   #2
QuoteOriginally posted by ndhonghai Quote
This will definitely be improved in the next DSLR- Prime M in the K-01 is already a lot faster
I'm personally expecting the K-3 (or whatever they'll end up calling it) to have an entirely different body design, so I hope Pentax makes it handle even better than the K-5 while addressing issues with the current ergonomics (which are minimal if you ask me, but I do agree with most of your points).
04-16-2012, 01:02 AM   #3
twitch's Avatar
Apart from the obvious (we have enough threads on that already):
Faster image processing engine
04-16-2012, 01:07 AM - 1 Like   #4
RobA_Oz's Avatar
Not quite sure if we're talking about the same thing, but auto image rotation is an option in the Playback/Review Menu.
Otherwise, your suggestions are a good list of nice-to-have features. The main things I'd like are improved AF speed (a common wish, at least here in the Forums) and I'd really like viewfinder blinds (sorry to go on about them, but with the sun at your back, using Live View or simply holding the camera above your head to get a shot introduces stray light into the eyepiece, and my thumbs aren't that long ). A 35FF sensor in the same body would be nice, too, but not absolutely essential.
04-16-2012, 01:20 AM   #5
Vignette lens correction
I'd like a vignetting correction as seen in some other brands. Some DA lenses suffer from severe
vignetting, eg. the kit lens at 18mm. And make all lens corrections hardware accelerated.
The current firmware implementation is annoying.
Regards,
--Anders.
04-16-2012, 01:24 AM   #6
QuoteOriginally posted by RobA_Oz Quote
Good thoughts, especially improved AF. Perhaps AF systems will never be quite good enough, but the technology is available to do better right now.
But I do think a FF sensor is essential, because it allows us to take full advantage of our current FF lenses, and gives us the full DOF control and wider angles that we paid for, especially with lenses like the FA31.
Both of the above only matter because Pentax has great glass that we want to use to the fullest.
04-16-2012, 01:27 AM   #7
Focusing issues and vignetting correction are long war that all camera brands are fighting.
We should give them things that possible to update/fix in next firmware.
04-16-2012, 02:15 AM   #8
the 2times delete button, custom timer, and the calibration of the electronic level, can should be a firmware update for the k-5
IMO a better low light AF is a must, instant review can be achieved with a new, faster processor, you can have instant review right now if you disable the lens distortion and chromatic aberration correction... some ergonomics could be better, quality control should be definitely better, especialy with all these "button fell off" threads...
04-16-2012, 02:43 AM - 1 Like   #9
-More and smaller crossed AF points.
-1080 and 720p video output to capture 60 to 100 fps with full manual control and full time AF.
(the apsc sensor is easily 5 to 10 times larger than those expensive *cost like a small car* Full HD camera that used in hollywood film making industry, hence the reasonably priced WR K3 should be a hit with the Steven Spielberg wannabes!)
-dedicated video button.
-better AF-C performance.
-dual card slot.
04-16-2012, 03:57 AM   #10
bwDraco's Avatar
Autofocus is the most critical matter (see https://www.pentaxforums.com/forums/pentax-dslr-discussion/181885-analysis-pe...provement.html for more information on how PENTAX can improve AF); almost as important is dual UHS-I capable SDXC slots. As it stands, these are the only major missing features (at least to me) in the K-5. Video shooters will certainly appreciate a dedicated video button.
--DragonLord
04-16-2012, 05:03 AM   #11
Bob from Aus's Avatar
Want a really good track focusing system like Nikon
Want any new model to be compatible with everything on the K5
04-16-2012, 05:18 AM - 1 Like   #12
drougge's Avatar
QuoteOriginally posted by twitch Quote
This annoys me too. Not as much as the AE-lock not working properly in manual though (ISO).
The last time I mentioned this several people argued there was something wrong with my brain, so I'll give an example of when it would be useful:
I have the exposure as I want it, with whatever aperture I want. I'm at say ISO 200, shutter 1/30. Now I see something moving, I want to shoot it at 1/250. This needs ISO 1600. I now want to press AE-L and turn a wheel 6 clicks. This works if I want to open my aperture three stops and I'm using a lens where the camera controls the aperture. Neither is likely to be the case, and I want the camera to adjust the ISO. (I actually have to turn a wheel 6 clicks, press ISO and turn a wheel 6 more clicks, which isn't as quick. Really, it isn't.)
I could accept having to press ISO as well, but I should only have to do that with a lens with camera controlled aperture. (And a setting where it defaults to moving the ISO would be preferred.)
If there is some enormous philosophical barrier to having this in a mode called "manual" I don't care if they call it something else, but please don't argue that I should use an automatic mode, it's not equivalent. And there is a place for a manual mode which isn't actively sabotaging me, even if most people would never even notice it's there.
Sorry for ranting.
04-16-2012, 06:18 AM   #13
and manual ISO control in movie mode
04-16-2012, 07:17 AM   #14
These things would make the K5 a better camera
Instant image review - like Nikon cameras have based - get a p-rom. I don't want to wait several seconds for a review.
Take advantage of fast SD cards. At the moment the K5 is compatible, but not taking advantage of really fast cards.
Software control - tether.
Better quality control or better engineering.
What I really want
Electronic viewfinder with live view. No more mirror boxes... Lenses that take advantage of such a design!
04-16-2012, 10:23 AM   #15
Want a better K-5? Make it full frame.
button, camera, dslr, k-5, k-5 ii, k-5 iis, k5, lock, pentax, pentax k-5, press, timer, user
Ricoh... Improve Pentax's Sync Speed! =) richard balonglong Pentax DSLR Discussion 42 09-04-2011 06:04 AM
T-Shirts and things with PENTAX logo blulagoon Photographic Technique 3 02-23-2011 10:21 PM
If the next Pentax body doesn't significantly improve AF, I'm getting a Canon. Unsinkable II Pentax DSLR Discussion 211 01-31-2011 04:08 PM
Landscape Need help to improve myself RasDil Photo Critique 5 01-22-2011 04:03 AM
A couple of things I'd like to improve in my shots Tom Brown Pentax DSLR Discussion 39 02-16-2007 10:22 AM
All times are GMT -7. The time now is 04:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
