04-18-2012, 12:22 AM   #1
Source of dust behind screen?
I've noticed some dust in my screen that definitely wasn't there when I got it, and I have no idea where it could possibly enter a weather sealed camera.
Has anyone else had this issue before? I'm planning on leaving the dust that's already inside, but I don't want any more to get in as they are quite visible in certain situations.
04-18-2012, 01:08 AM   #2
Presumably the rear LCD? If under warranty, take the camera in for repair. The rear LCD should be water tight. This seems to be an issue with some K-5's at present.
The dust is getting in because the seal has failed; zoom action of the lens is acting as a 'pump', and the air has to enter/exit somewhere! Water and dust get in the same way.
04-18-2012, 03:45 AM   #3
Oh that sucks. I actually 'use' the weather sealing quite often. It's under warranty in Europe so that doesn't really help.
04-20-2012, 11:13 PM   #4
nah
I had the same problem. It's a bad seal on the rear plastic/glass screen. Make sure they replace that seal if you send it in for repairs. The first time they only cleaned the dust and didn't replace the seal/rear screen and the dust came back.
04-21-2012, 08:01 AM   #5
Shit happens, I would say.
There is always wear and tear inside a camera, gears are moving, the shutter is moving... Maybe some piece of dust was in the camera and founds its way to a spot where you can see it. Weather sealing is nice, but as soon as you take the lens off, additional dust can come inside.
04-23-2012, 11:16 PM   #6
I hope it was already inside the camera. Anyway, even if I can't get it fixed, it's reinforceable with a screen protector.
04-24-2012, 12:59 AM   #7
nah
QuoteOriginally posted by Trysaeder Quote
I wouldn't settle. If you search the forums, there are numerous people that had this problem. It's a bad seal, if dust can get in, imagine what water would do?
Send it in.
04-24-2012, 03:06 AM   #8
It's not under warranty. If chance allows, I might pass by the pentax distributor with my k-5 on me, and I'll do something about it.
camera, dslr, dust, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Dust underneath K-5 LCD screen!!! Feudal1 Pentax K-5 59 04-22-2014 05:08 AM
Dust UNDERNEATH sensor screen of a K-7 - Help !!! Jean Poitiers Pentax DSLR Discussion 2 09-03-2011 05:25 PM
K-7 dust in LCD Screen?? shang Pentax DSLR Discussion 4 09-13-2010 04:43 PM
Dust in focus screen tbirdas Pentax DSLR Discussion 2 09-06-2010 07:34 AM
Source for split image focus screen for K10 jimH Pentax Camera and Field Accessories 21 05-05-2009 07:12 PM
All times are GMT -7. The time now is 09:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
