04-21-2012, 05:55 PM   #1
joe.penn's Avatar
K5 Mirror Flop | Flip | Flap - Ummmmmm
Ok - well, K5 is acting a little on the strange side. During Hi-Speed Burst shooting it SOUNDS and FEELS like the mirror/shutter gets out of sync; it's really hard to explain actually being that it is still taking the snaps correctly.
So, instead of the smooth
CLICK | CLICK | CLICK | CLICK | CLICK <- fast at 2000th and greater
It will be something like
CLICK | CLICK | CLCLCLCICK | CLCLCLCICK | CLCLCLCICK - almost like a dragging feel and sound
This is happening every so often and not at every interval I shoot in burst - so I may have 2 or 3 rounds where it works perfectly then I will hit a round where the strange behavior happens. Has anyone experienced this before?
04-21-2012, 05:59 PM   #2
wcchamp18's Avatar
Sounds like a trip to Phoenix is in order!
04-21-2012, 06:01 PM   #3
joe.penn's Avatar
QuoteOriginally posted by wcchamp18 Quote
Arggghhhhhhhh - not again!!!!
04-21-2012, 06:07 PM   #4
Philoslothical's Avatar
What's happening with the output of it? Are you getting black frames, or partially black?
04-21-2012, 06:15 PM   #5
joe.penn's Avatar
QuoteOriginally posted by Philoslothical Quote
No, still getting images fine - but I think it may be skipping an image or 2 in the sequence (like maybe getting 1,3,5,7 and not getting 1,2,3,4,5,6,7), hard to tell though since the action is going by so fast. It's either that or its only giving me 3fps instead of 4 or 5fps like it should for the given shutter speed...
04-21-2012, 06:27 PM   #6
If you're not getting damaged output, and the file numbers are in sequence, I think you're quite lucky. At least, it could be a lot worse.
I wonder, if you took a digital stopwatch that does milliseconds, if you could figure out what it's missing, if anything. It might give you some indication if it's really shooting/flopping erratically, or if it just sounds like it.
You can also figure out fps by recording the sound the camera makes, and then checking the time between the series of pulses. This wouldn't help to show any variations in exposure, or anything like that (which is why shooting the stopwatch came to mind first).
04-22-2012, 09:29 AM   #7
Photograph a spinning rainbow wheel, if it's OK you should get photos in a sequence. If any photo gets left out you'll see the jump.
camera, click, dslr, k-5, k-5 ii, k-5 iis, k5, k5 mirror flop, pentax k-5
K-r double flip mirror issue kinda fixed mikerigel Pentax K-r 14 09-26-2012 05:47 PM
Mirror Flop?? Billgscott Pentax K-5 8 11-21-2011 11:46 AM
Brief Word On Mirror Flop GarySloman Pentax K-5 16 11-13-2011 06:36 PM
mirror flop in live view?? CEWren Pentax K-5 5 09-05-2011 07:14 AM
Double mirror flip problem K-r with M42 lens au22ru Pentax DSLR Discussion 11 07-22-2011 04:17 AM
All times are GMT -7. The time now is 06:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
