04-30-2012, 04:48 PM   #1
LaurenOE's Avatar
Diopter Adjustment
Ok, here is an obscure question.
I wear a -5 diopter contact lens in my right eye.
Most of the time, I wear glasses.
Sometimes, especially in humid conditions, I have to take pictures by flipping my glasses up as they fog up from being close to the camera and the humidity.
The K5 doesn't adjust enough when I move the diopter adjustment to the Right - which says " - " on the slider.
In the K5 manual (page 61) it says, that I can adjust the diopter -2.5 to 1.5.
It also says that if that's not enough, that I need to buy the correction lens adapter.
So what is the consenus? Should I get a -5 or -4 or -3?
04-30-2012, 05:03 PM   #2
dms
A question that perhaps you should ask is how convenient is it to switch between glasses and glasses, off much of the time.
I have a diopter for my Nikon FM2, and except for unhurried landscapes and macro I find removing my glasses for each shot to be a major pain. I suggest you ask your optometrist if there is a diopter that would allow you to use the camera adjustment (one extreme) to allow you to use glasses + diopter, and still use the camera adjust (other extreme) + diopter w/o glasses.
If it is not feasible--maybe a drop down (hinged) diopter (like some 2x magnifiers). As far as the diopter strength (your question) I believe Pentax should be able to tell you the effective (camera) system diopter value and thus what the eyepiece should be.
04-30-2012, 06:26 PM   #3
LaurenOE's Avatar
QuoteOriginally posted by dms Quote
Good points. There are the occasional times I *need* to use my naked eye. I have the Ref-converters - as for additional diopter adjustment - but they too, fog up with my glasses in those special/humid times.
Since I wear my glasses 99% of the time, I would put the diopter corrector in my kit to be available for those special times. That is my plan.
04-30-2012, 08:42 PM   #4
You should check with your optometrist as to whether your glasses prescription is the same as the contact lens. I wear -8 on the left and -8.5 on the right (contact lenses), but my glasses are around -9 to -10.
adjustment, camera, diopter, dslr, glasses, k-5, k-5 ii, k-5 iis, k5, lens, pentax k-5
K-7 Diopter Adjustment lever Mike.P Troubleshooting and Beginner Help 12 01-23-2015 04:25 PM
Where to find 67 diopter? Mike Pentax Medium Format 12 02-12-2014 08:28 AM
K-20D Diopter adjustment at limit Sigmoid Pentax DSLR Discussion 3 06-24-2011 06:50 PM
Diopter adjustment -Mous- Pentax DSLR Discussion 11 04-26-2011 03:47 AM
What is your diopter adjustment? jake123 Pentax DSLR Discussion 24 08-22-2009 10:56 AM
All times are GMT -7. The time now is 12:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
