05-08-2012, 11:42 PM   #16
Wheatfield's Avatar
As I said, stuff happens. If you read the forums dedicated to other camera makers, you will find stories from all of them regarding the occasional problem camera. I'm not saying it is right, wrong or anything at all, but it is reality, and being professionally offended isn't a constructive way to face the facts.
If something like this really pisses you off, you should probably not every buy anything, since everything you buy will have the same potential to really piss you off.
I feel kind of sorry for you, you must have a miserable life.
05-08-2012, 11:55 PM   #17
This is interesting. I've had my K-5 for about 3 months and so far my best shots have all been MF. AF always seems to be slightly off. Maybe I'll send mine in when school is up next week.
edit: Although I do remember reading about the focus sensors not being as small as advertised through the viewfinder, which is a serious bummer.
05-09-2012, 12:27 AM   #18
thanks
Thanks for all you help it is appreciated , i will return this k-5 tommorow and have them send me a new one. as one forum member said shit happens, well i got a bad one, but i am sure the next one will be fine. its fortunate we have so many knowledgeable people out there.
05-09-2012, 12:28 AM   #19
no, my life is great
05-09-2012, 12:28 AM   #20
pissed off is propabley wrong it should have been strong disapointment.
05-09-2012, 12:34 AM   #21
yur right i meant very disapointed illsend this back and have agood one in a week or two, i am not a very patient person also.
05-09-2012, 02:11 AM   #22
Think positive. At least you didn't drop $3000 (body only) on a Nikon D800.
It's also been having focus problems, amongst other bugs.
05-09-2012, 06:00 AM   #23
Wheatfield's Avatar
Perspective is everything.
05-11-2012, 12:20 AM   #24
talked to a pentax service rep, he said the prism was out of alighnment and that some times these things happen, ( nice young man ) and the response from my email to pentax was super quick. anyway I will have my replacement k-5 soon.
05-11-2012, 12:24 AM   #25
will not relevent to my problem i did try one of my old manual focus primes on the k-5 and with the large viewfinder manually focusing was super easy, much better than my kx wich i have found manually focusing to be hard for me.
05-11-2012, 04:43 PM   #26
Zafar Iqbal's Avatar
Does your K-5 *always* mis the focusing when autofocusing, or only occasionally?
I just got a K-5 too, and noticed quickly it doesn't lock the focus on the correct spot under certain light types. It can focus perfectly fine under different lighting conditions, even if they are dimmer.
05-14-2012, 10:03 PM   #27
For the record, I just tested my D FA 100mm with the macro chart from
PENTAX DSLRs: Front or Back Focusing Problems? Free test (Lens Alignment) charts for Pentax, Nikon, Canon, Sony, Olympus.
and it was so back-focused even a full +10 fine AF adjustment can't bring it perfectly back, although granted it is much closer now. It's possible I didn't set up the test right, but everything was level and I shot multiple times, and even did one manual focus shot (which obviously was perfect as it was manual focus).
It's getting late, so I'll test my DA 18-55 tomorrow and see what the results are. I believe I read a thread around here where a member stated all his glass was back-focused and it turned out to be the camera.
Like I said it's possible I set up the test wrong, but I'm not too pleased tonight.
05-15-2012, 11:47 PM   #28
loveisageless's Avatar
It is too bad that newer K-5 are turning up with these problems so late into the product cycle. All cameras seem to have some glitches upon release. I suspect that the D800's will be addressed by Nikon post haste. The D800 is being adopted by professional photographers, and is often being chosen over the D4. Nikon has to respond or risk losing sales to Canon. If you see used D800 bodies for sale, turn and go in the other direction, since the fix is only now making its way to repair facilities.
camera, dslr, focus, k-5, k-5 ii, k-5 iis, k5, kx, lens, pentax, pentax k-5
Focus, Focus, Focus (or the usefulness of focus charts) GoremanX Pentax DSLR Discussion 31 12-21-2014 11:49 AM
K-5 Manual Lens Front Focus & Focus Beep woes fixed kneonx Pentax K-5 14 04-12-2014 03:47 PM
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
Focus Ring on DA 35 macro makes a clicking noise; manual focus ... this normal? eadrian75 Pentax SLR Lens Discussion 2 04-12-2011 12:51 AM
Confirm my understand of metering w/ manual lenses focus hyperfocal focus DeadJohn Pentax SLR Lens Discussion 4 03-25-2011 12:31 PM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
