05-09-2012, 11:08 PM   #1
K-5 AF fine tuning question
I am able to fine tune 3 of my lenses by following instructions that I found on the followng link
PENTAX DSLRs: PART-1. Autofocus Adjustment charts for front and back focusing problems. Good for Pentax, Canon and Nikon.
But I wonder if I am compromising on anything at all by doing so? If yes, what am I compromising?
Thanks
Mouli.
05-09-2012, 11:34 PM   #2
Are you actually having AF problems to begin with?
05-10-2012, 12:44 AM   #3
you may download some free af test charts from here
i found that the ff or bf depends on the type of the light... red light=crazy ff... but white or yellow is spot on... maybe in warm light its like 1mm ff but not in all cases, so i left the settings untouched.
05-10-2012, 01:08 AM   #4
AF does vary dependent upon light wavelength, i.e. if autofocussing in daylight vs. tungsten the accuracy could vary, especially if the light level is also low.
What are the lenses? If zooms, you could find that the af will be out at one end of the range if you set up at the other.
05-10-2012, 08:37 AM   #5
all in all you are not compromising anything, as long as you have in mind that the autofocus performance changes depending the light wavelength...
if you shoot in specific light conditions then you can perfectly optimize the AF.
if you want an all around setting, well, it wont be perfect... you have to optimize for the light conditions you usually shoot, and compromize for the less used conditions... or remember the settings and change them accordingly.
camera, dslr, k-5, k-5 af, k-5 ii, k-5 iis, k5, pentax, pentax k-5
K200D autofocus fine tuning. polur101 Pentax DSLR Discussion 30 02-09-2014 02:23 PM
Tuning your glass chuckp8 Pentax K-5 13 12-17-2011 05:54 PM
AF Fine Adjustment, focus correction, AF micro adj., AF fine tuning annajonna Pentax K-5 13 11-19-2011 11:32 PM
Tuning in from WAIKIKI, West Australia nightjar Welcomes and Introductions 2 10-16-2010 09:40 PM
K20D with AF Fine Tuning? blende8 Pentax News and Rumors 12 12-17-2007 06:36 AM
All times are GMT -7. The time now is 05:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
