Originally posted by kkennally I figured it was pointless but it was the only change I made to the camera when the problem began.
If there is some weird bug, it could very well be you are right. Coding is like that -- it is the bugs that make no sense that don't get caught. I doubt it would be so simple as "set to DNG", but "set to DNG" + "all the other settings set to exactly what you have them set to" could very well create a problem. I am a programmer, and seem to have a special knack for finding bugs in software that no one else has seen before. I've seen much weirder ones.
Still, more likely you've got a loose wire or some circuitry isn't doing its job controlling voltage on startup. If you happen to be using a non-OEM battery, I'd be very suspicious of it.
