05-16-2012, 04:09 PM   #1
Bracket?
Hello Folks,
Does the K-5 have an automatic exposure bracketing function? If so, what is it called, so I can look it up in the manual?
Thanks, Tom
05-16-2012, 04:13 PM   #2
yes, p.157 in the manual
05-16-2012, 04:14 PM   #3
RM Barker's Avatar
Yes, called "Exposure Bracketing", pps. 157 - 161
05-16-2012, 04:24 PM   #4
Thank you.
05-16-2012, 04:38 PM   #5
Hello Again,
I followed the instructions, but my camera does not respond the way the manual says it should. When I press the four way controller ^ only three options are offered, and exposure bracketing is not among them. Is it possible that a firmware update would cure this?
05-16-2012, 04:53 PM   #6
Verglace's Avatar
The firmware that came with it should have that functionality. Maybe another setting is blocking it, try switching to raw and see if you have that option.
05-16-2012, 04:53 PM   #7
What mode are you in? I don't think you will see the option for Exp Bracketing if you are in green box mode.
05-16-2012, 04:55 PM   #8
This is because you are in "Green Mode"--Change mode sw to other modes like P/AV etc and you will have access to Exposure Bracketing as one of your drive modes---^ on four way controller.
05-16-2012, 04:59 PM   #9
Ah ha! I stitched to Av and the function became available. Thank you. You guys are the best. Sincerely, Tom
05-16-2012, 05:00 PM   #10
I have my RAW button set to Exposure Bracketing. Makes it a snap to bracket quickly.
05-17-2012, 03:45 AM   #11
Col
Col's Avatar
QuoteOriginally posted by riveredger Quote
True, but it doesn't help you to stop bracketing quickly, which is why I has to take it back off.
05-17-2012, 04:21 AM   #12
adwb's Avatar
oh good, I though it was just me, the only way i found to turn it off was via the 4 way controler or am I misssing something?
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
L Bracket for Pentax 67 rajith Pentax Medium Format 4 02-08-2012 05:32 PM
K7-Can you Bracket different Apetures? Tonto Troubleshooting and Beginner Help 10 03-12-2011 11:16 PM
Flash Bracket Recommendation Deiberson Flashes, Lighting, and Studio 13 12-21-2010 02:04 PM
RRS L-bracket for the K-5? Todd Adamson Pentax K-5 14 12-06-2010 08:44 PM
All times are GMT -7. The time now is 08:05 AM. | See also: NikonForums.com, part of our network of photo forums!
