05-21-2012, 10:50 AM   #1
WightWalker's Avatar
Shake Reduction - Curse or Bonus
On my K10, I just left it switched on & never had a blurry or unfocused shot as a result of SR.
With the K5, is it my imagination, or does the 'hand' take an age to light up in the viewfinder to indicate that SR is active. If it's necessary to wait for this prior to pressing the shutter, then wouldn't it make sense to include an option, similar to focus, such that you can't depress the shutter until SR is lit.
Fortunately, my number of failed shots is buried in the noise, so as to speak, but it's still annoying when it happens particularly when you've selected a high shutter speed with a long lens using the 1/focal length 'rule of thumb'.
05-21-2012, 10:53 AM   #2
MSL
MSL's Avatar
From what I've read elsewhere on the forums, once you have high shutter speeds, whether SR is on or not shouldn't matter. So under those cases, if the SR prevented you from taking the picture that would be a bad thing as you'd likely miss shots, or you should just turn the SR off.
05-21-2012, 11:29 AM   #3
imtheguy's Avatar
QuoteOriginally posted by WightWalker Quote
....... then wouldn't it make sense to include an option, similar to focus, such that you can't depress the shutter until SR is lit.
K-5 Menu --> Custom --> #15 AF.S Settings --> Focus Priority
Does pretty much what you are asking about.
05-21-2012, 12:29 PM   #4
QuoteOriginally posted by imtheguy Quote
No it only gives you the option for focus; I was suggesting that an additional option for SR to compliment Menu --> Custom --> #15 AF.S Settings --> Focus Priority
05-21-2012, 12:30 PM   #5
I guess it's your imagination, if anything it's slightly faster then the K10. Anyhow, if you don't want to wait for it, don't wait for it. The result will be the same as if the SR was shut off. Some people claim that that will ruin the shoot, but I doubt it, there is no technical reason for that as far as I know.
05-21-2012, 01:11 PM   #6
imtheguy's Avatar
Of course.
I'm in idiot mode today.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shutter, sr
Shake Reduction Wolter Pentax K-5 11 04-08-2011 06:50 AM
Shake Reduction on or off? GoldenRGuy Pentax DSLR Discussion 7 02-16-2011 08:37 PM
When to use Shake Reduction? Todd Adamson Troubleshooting and Beginner Help 9 11-04-2010 05:36 AM
Do you always have shake reduction ON? gawan Photographic Technique 18 08-01-2010 02:36 PM
Shake Reduction hannsg Troubleshooting and Beginner Help 5 06-11-2010 03:45 PM
All times are GMT -7. The time now is 01:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
