05-21-2012, 10:58 PM   #1
Manual vs Auto Focus
Does the K5 record whether the shot was taken using manual or auto focus?? If yes where can I find this info?
I did a series of test shots and did not record which were in manual & which were auto. I assumed the K5 would record that info along with aperture, speed, ISO etc. I can not find this info. Did I waist my time on the test shoot?
05-21-2012, 11:15 PM   #2
hcc
hcc's Avatar
Yes, the photograph EXIF does include the info. It is shown in PDCU (as Autofocus mode). You can read also the EXIF info with Photome (photome.de) under Focus mode.
I hope that the info will help.
05-21-2012, 11:42 PM   #3
Even better, PhotoMe can read the EXIF and show which AF point was being used in each shot:
EDIT - this may not work reliably or at all for Pentax cameras.
I also deleted the image from PhotoMe in this post showing this feature at work, since it shows a Nikon body.
05-21-2012, 11:45 PM   #4
QuoteOriginally posted by hcc Quote
BIG HELP!!! Thanks
PhotoMe is incredible, thanks for the heads up.
05-21-2012, 11:55 PM   #5
hcc & rawr Thanks great info.
Since you both seem very knowledgeable. one more related question, can you tell the K5 to recognize Non DA lenses you use all the time and have it record it in the EXIF file? I have the Pentax A 300mm F2.8 and the Pentax A 200mm F4 Macro which are not recognized. I was testing the Sigma 150-500 & would love to have that recognized as well.
05-22-2012, 12:38 AM   #6
hcc
hcc's Avatar
Bela,
With the K-7, I do not believe that there is such a function. I assume that it could be the same with the K-5.
05-22-2012, 02:24 AM   #7
You (AFAIK) can't tell the camera to recognize a lens that it doesn't already have a EXIF LensType code for in it's firmware.
The less elegant solution is to write the lens values you want into your image EXIF in post-processing. A variety of tools will let you do that, including EXIF tools like EXIFtool itself, EXIFtoolGUI, PhotoMe, or image managers like Lightroom, and many others.
05-22-2012, 04:20 AM   #8
But as far as I know,
  • Even if the camera does not know the lens, it will still put the lens ID in the EXIF info. And tools like photome (if it knows about that lens) can translate that.
  • A non-Pentax lens might be identified incorrectly
  • A-lenses don't identify themselves
05-22-2012, 05:14 AM   #9
Can you tell how to use this feature for Penatx files? I can't get PhotoMe to cooperate (AF icon is red X-ed out)!
05-22-2012, 12:30 PM   #10
QuoteOriginally posted by jmg257 Quote
First thing is to make sure you have an image file with full EXIF intact.
Make sure you are using PhotoMe 0.79, not the 0.8beta
Then open the image in PhotoMe.
Immediately you will see a preview of the image in the bottom left (under 'Thumbnail') which shows the AF points used if you click on the little '[AF]' icon above the thumbnail.
You can also go into the manufacturer's notes section and see under the AF section a text entry for 'AF points in focus' which will say which points were in use.
While an option for displaying a big graphic of AE metering segment data DOES come up for Pentax cameras in the manufacturing notes section of 0.79, a big graphic indicating AF points in use DOESN'T seem to come up reliably for Pentax cameras in 0.79, if it appears at all. Maybe it only works reliably for some Nikon or Canon models. So sometimes the small thumbnail display of AF point in use is all you might see.
05-22-2012, 02:02 PM   #11
Thanks, rawr!!!
Cheers!
05-22-2012, 04:46 PM   #12
FWIW, if you have a Mac (I don't, so can't verify) Apple's Aperture 3 image manager also lets you view an AF point overlay on your images that highlights which AF points were active (under the Metadata Inspector tab).
Hover over the Focus Points button in the Camera Info pane to see the focus points used by your camera to autofocus the image. You can also click the button to turn the display of focus points on or off.
Apple don't say this feature doesn't support Pentax, so it probably does.
11-04-2012, 01:10 AM   #13
Exiftool works very well when integrated with Automator on Mac. I have written a step-by-step guide available here on my website.
auto, camera, dslr, info, k-5, k-5 ii, k-5 iis, k5, pentax k-5, record, test
Can't change from Manual focus to Auto Focus kellyy17 Pentax K-r 11 03-06-2013 09:37 AM
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
auto/manual focus problem ndarby1 Troubleshooting and Beginner Help 6 12-10-2011 02:00 PM
Problems auto focus assist in manual tonybolo Pentax SLR Lens Discussion 5 06-11-2011 06:20 PM
manual focus, auto aperture 55? Impartial Pentax SLR Lens Discussion 4 10-12-2010 05:36 PM
All times are GMT -7. The time now is 01:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
