05-22-2012, 12:49 AM   #1
tabl10s's Avatar
Adjusting Flash output.
How do I do it on the built-in flash?
05-22-2012, 01:38 AM   #2
calsan's Avatar
Which camera body? On my k-7 you push the flash button on the 4 way controller to show the flash settings screen and then turn the rear e-dial to adjust.
I normally only use this if I'm very close to the subject.
Look for 'compensating flash output' in the basic operations section of your manual.
05-22-2012, 12:34 PM   #3
cbope's Avatar
QuoteOriginally posted by calsan Quote
It's the same on K-5.
05-22-2012, 01:36 PM   #4
tabl10s's Avatar
Thanks. Will the same procedure work a mounted flash?
06-02-2012, 07:27 PM   #5
i just tried to do this and ive gotten the same exposure on both -2 and +1... manual mode 125 shutter f8 iso 100. both exposures look exactly the same. am i doing something wrong?
06-02-2012, 09:00 PM   #6
QuoteOriginally posted by ckswong Quote
If you are using a Pentax A series or above lens, put the camera in P mode and try again.
Also are you using the in-built flash or an external? If it is an external flash, not all of them may support flash exposure compensation.
06-02-2012, 09:06 PM   #7
wow thats qwirky, so it only works in p mode?
06-03-2012, 06:00 AM   #8
Of course not. Flash output adjustment with the built-in flash works in TAv, M etc. The only mode it DOESN'T work in is the green mode. (see p-82 of the K-5 manual).
P mode is just an easy way to ensure that it works for you by minimising your input and letting the camera do the work. So if it works in P mode the problem is not the camera but your equipment (eg a non PTTL external flash) or how you have made your settings.
06-03-2012, 06:13 AM   #9
sterretje's Avatar
Can you also answer the questions that rawr asked in post #6 You might get some sensible answers
06-03-2012, 08:23 AM   #10
using a sigma 18-50 dc lens with bulit in flash. i thought i wrote it down!
06-04-2012, 09:10 PM   #11
tabl10s's Avatar
Like Wong, the light output looked the same no matter the +/- setting.
06-05-2012, 12:14 AM   #12
steve1307's Avatar
Huh, I've used before on a K-7 and Pentax lenses with contacts, it works within limits.
If you are too far away no amount of +ve FEC is going to ork
If you are too close and or ISO too high then dialing in -ve FEC wont correct it either.
The built in flash is P-TTL so it tries to expose the subject correctly. If you dial in +1 it tries to expose over by 1 stop. If you dial in -2 it tries to expose under by 2 stops. You are just setting its target exposure not boosting the power.
If the scene is really dark and your manual settings already have the flash P-TTL at its maximum output anyway if you had 0 FEC dialled in then if you turn it up to +1 you don't get more flash the exposure will look the same.
If its really really really dark and to have - 2 FEC dailled in and the flash is still firing at full power to try to give you the result then it will look the same not matter if it is -2, -1, 0 or +1
Put it this way your flash "only goes up to 10". You can't "turn it up to 11"
06-05-2012, 04:27 AM   #13
tabl10s's Avatar
How do you override the TTL?
06-05-2012, 04:55 AM   #14
WightWalker's Avatar
QuoteOriginally posted by tabl10s Quote
Not strictly related to the topic but I found this useful to control the flash output to have some control over depth of field - using P Mode always seems to use the lens wide open with a narrow depth of field.
Use the Guide Number against the ISO to calculate the f stop against distance
i.e.Aperture = ISO Guide Number / Distance in metres
or use the table below which I prepared for my use to enable better control over depth of field.
Use Av or M Mode; the latter allows the ISO, Aperture & Shutter Speed to be set.
06-05-2012, 06:44 AM   #15
steve1307's Avatar
I just tried the same thing M mode f8 , 1/125, iso100 in a fairly dark indoor room with a subject at about 4m away. I used a fairly dimly lit room so the ambirnt lighting wasnt too significant in the test.
In my room test at iso100 f8 correct exp is 4seconds so 1/125 is 9 stops underexposed!!
At 4metres all shots with FEC of -2, 0 and +1 look pretty much the same. I went up to 1m from the subject then the flash has more of an effect so the 3 tests shots -2, 0,+1 do differ.
QuoteOriginally posted by WightWalker Quote
I tested at the scene again distance 4m f8 but with iso cranked up to 800 as per this table and the exposure looked much better.
The built in? Well i don't think you can switch off the P-TTL but if you use a lens without contacts (like and "M" or "K" series) it will just fire at full power. You can always short out the contacts on an "A" series or newer with a piece of foil to fool the camera into thinking its an M lens. but that seems to be too much effort. GN of 13 is pretty puny anayway.
Best solution is just to buy an external flash, if it does not have P-TTL (or TTL) capabilities then great just set your power to 1/1, 1/2, 1/4, ......1/128 or whatever. These are cheaper generally
If the flash like most of the current Pentax, Metz, Sigma has all the fancy P-TTL functions or built in lightmeters you can use those in the same way by switching to M mode.
camera, dslr, flash, k-5, k-5 ii, k-5 iis, k5, pentax k-5
How to determine output of a flash gun in watts? bluebronco Flashes, Lighting, and Studio 13 03-22-2012 06:57 AM
Higher output flash for K5 mokey Flashes, Lighting, and Studio 17 04-09-2011 11:17 AM
Interesting thread; adjusting output on the Pentax flashes Russell-Evans Flashes, Lighting, and Studio 22 01-06-2011 08:41 AM
"Raw to Jpeg" color different in Camera output and Pentax software output provia Digital Processing, Software, and Printing 6 07-11-2010 01:18 AM
Any way to reduce on-board flash output with manual aperture lenses? Eruditass Pentax DSLR Discussion 9 04-08-2010 10:00 AM
All times are GMT -7. The time now is 06:47 PM. | See also: NikonForums.com, part of our network of photo forums!
