05-28-2012, 11:26 AM   #1
jpzk's Avatar
CIF (catch-in-focus) and going back AF ...
I have enabled the CIF option with my K5 and I find it very useful, espeially with my DA*300/4 lens.
Now, I am wondering: when I want to go back to AF mode on the lens (i.e.: I switch the little lens AF/MF silder from MF to AF) ... do I have to bother going back and change the CIF option as well?
Does it matter?
This is probably a "beginner's question ... but I had to ask anyway.
Thanks!
JP
05-28-2012, 11:34 AM   #2
RioRico's Avatar
I have a K20D and no AF lenses with AF/MF switches but I do no menu-diving to change AF-MF modes, I just flick the AF switch. I use the positions like this:
* AF= AF.S for CIF
* AF= AF.C for AF
* AF= MF for unaided MF
To use CIF with an AF lens, I push the K20D's lens-lock button and the shutter at the same time. Pushing the lens-lock button retracts the AF screwdrive so the camera can't tell an AF lens is mounted, thus allowing CIF. From this, I'll wager that flipping the on-lens AF/MF switch will be enough to convince the camera that is has an MF lens and thus employ CIF.
Hope this helps! (Or at least makes sense...)
05-28-2012, 11:42 AM   #3
jpzk's Avatar
* AF= AF.S for CIF
* AF= AF.C for AF
That is one neat trick that I didn't know !
I suppose what you say is true: flipping that switch to MF would simply "make" the lens manual.
So, there is no need to worry about getting back into the menu and opt out the CIF?
JP
05-28-2012, 11:46 AM   #4
RioRico's Avatar
QuoteOriginally posted by jpzk Quote
No, leave CIF enabled. Just flip switches for the mode you want.
05-28-2012, 12:15 PM   #5
jpzk's Avatar
OK, thanks for the tip(s).
Apppreciated!
JP
05-28-2012, 02:14 PM   #6
Jean Poitiers's Avatar
Agreed ...
That is one neat trick that I didn't know ! ...JP
Bonjour,
Interesting tip ... thanks.
J Frog
af, camera, cif, dslr, k-5, k-5 ii, k-5 iis, k5, lens, option, pentax k-5
catch in focus jennverr Pentax DSLR Discussion 20 04-07-2012 09:08 AM
CIF (catch in focus) unattended and remote - what are your set up's? jpzk Pentax DSLR Discussion 12 02-14-2012 09:37 AM
Help! The Bats are Back! Catch In Focus seachunk2 Troubleshooting and Beginner Help 9 07-08-2011 03:21 PM
catch focus in K-r sany Pentax K-r 14 06-12-2011 06:15 PM
Catch in Focus mand Pentax DSLR Discussion 18 02-25-2011 04:38 PM
All times are GMT -7. The time now is 12:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
