06-03-2012, 07:11 PM   #1
K-5 froze....why ?
I've had my K-5 since Nov. 2011.
Up to now it's worked great without a hitch.
Today...I pressed the shutter button and the camera froze. It was on, the upper window was on....but the camera didn't function...wouldn't respond to the shutter button...just froze. I couldn't turn it off.
I had taken a number of photos today and was in the process of taking another one...when it stopped working.
After about 10 minutes I decided to take the battery out...as that was the only way I could figure to turn it off.
The camera turned off...after I popped the battery completely out.
I then put the battery into the camera...and voila...the camera...once again worked perfectly.
What could the problem be ?
Will it happen again ?
06-03-2012, 07:23 PM   #2
lammie200's Avatar
Firmware version?
QuoteOriginally posted by lesmore49 Quote
...What could the problem be ?
Firmware version?
06-03-2012, 07:23 PM   #3
jpzk's Avatar
Read those:
Always a good idea to do a little serching before posting a question ...
https://www.pentaxforums.com/forums/pentax-k-5/163726-k-5-freezing-up-no-bigg...-annoying.html
https://www.pentaxforums.com/forums/general-technical-troubleshooting/170784-...e-upgrade.html
https://www.pentaxforums.com/forums/pentax-k-5/154738-my-k-5-freezing-issues.html
https://www.pentaxforums.com/forums/pentax-k-5/138275-replaced-k5-tested-freezing.html
06-03-2012, 07:41 PM   #4
imtheguy's Avatar
I'll just add that I am happy that you had a solid 6 months shooting before the first freeze. Either send it in for "repair" or get faster at popping the battery out. But seriously, changing batteries before they get too low may cure it for you. If it was a fresh battery, go back to sentence #2. ...and good luck!
06-04-2012, 01:05 AM   #5
Probably the logics in the firmware got screwed with multiple commands/loops during usage.
It can happen again, but rarely so (for me)
Anyway, I just take the battery out and pop it back in.
I've never run into or known of anyone who had this issue continuously such that it became impossible to shoot, so don't worry too much.
Hey! My latest and greatest Samsung Galaxy Note using the OS that was designed by the best paid and brainiest that Google and afford hangs up too (more often )
On a almost 1yr 9mths K5.
06-04-2012, 09:32 AM   #6
I've sent it in to Pentax for a check over. Thanks for the suggestions, much appreciated.
battery, camera, dslr, froze, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shutter
K-7 froze in video mode, now messed up dedmozaj Troubleshooting and Beginner Help 4 05-18-2011 04:26 PM
Nature "It is a thorn." and "Water froze in time." Danny Delcambre Post Your Photos! 1 04-15-2011 09:00 AM
K-X made clunking, vibrating noise then froze up Olypentax Pentax DSLR Discussion 3 03-11-2010 11:43 AM
All times are GMT -7. The time now is 09:10 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
