Originally posted by SpecialK I agree with everything, except the OP did not know about the stain issue until a few days ago.
You are right. I'm sorry I have mistaken his initial noticing of the stains with knowing that there is a general stains issue. It would not have been hard to find out about the stains issue. Google finds PF posts whether you are a member or not.
Originally posted by freddyhard i knew nothing about the sensor stains. i knew there were spots initially, but because i used wide apertures they did not cause a problem too often.
I'm sorry that I didn't catch that you only noticed the stains but didn't know about the stains issue.
I still maintain, though, that you don't have much of a leg to stand on for ranting because you "
initially ignored them". Hoping that they may go away by themselves and not following the issue up got you into the spot where you are now.
You can blame others and be rude to people, but if you don't learn from this incident then you are going to repeat the same mistake in the future. But why not, if one can blame others?
Originally posted by freddyhard if you did not read my posts then you should not comment. if you did, then i think you need your eyes tested.
I hope Pentax replaces your sensor free of charge. It would be the right thing to do.
Just as it would be the right thing to do for you to acknowledge your part in this story and be more respectful to people, even if they make a mistake.
