06-11-2012, 12:16 PM   #1
lammie200's Avatar
Focal length setting
I don't have my camera with me and I am just taking a break at work, but I thought that I would ask anyway.
Can you assign a button to change the focal length setting? I shoot a lot of manual focus and it would be helpful to change the focal length easily with a manual zoom to get SR to work properly. Another option might be setting up the User custom settings. Haven't done it though. Leaving the menu on the focal length setting is another option I suppose. Does anyone have any experience with this issue?
06-11-2012, 01:44 PM   #2
RioRico's Avatar
I don't think that option exists. I avoid SR with MF zooms, if I'm zooming. Better to shoot in good light with a fast shutter and SR off. If I *must* use SR with a MF zoom, I usually just set the lens and SR'bot to one focal length and leave them there.
06-11-2012, 02:07 PM   #3
lammie200's Avatar
I guess that begs my next question: What shutter speed do you need to shoot in order to make SR ineffective? I'll start a new thread so that trolls can apply as well.
06-11-2012, 06:06 PM   #4
RioRico's Avatar
I think I noticed that 'ineffective' thread. My answer to the specific question: slower than 5/FL, depending on your cam-handling technique. I'm trained for stable shooting (with a .45 ACP anyway) and I can get *some* acceptable shots when shooting so slow. Some, but not many, not freehand. If I'm at 5/FL or slower, I'm either braced against something, or SR is off and the camera is immobilized and I use shutter delay.
Falk Lumo's tests showed SR giving a gain of 2-4 f-stops depending on focal length and shutter speed. I recall an absence of negative effects of SR at any speed, if the focal length is entered accurately. But I think once you drop below the 4-f-stop threshold, SR may not be of much use. Which is why I don't shoot my 1000/10 mirror handheld at 1/100!!
06-11-2012, 09:14 PM   #5
maltfalc's Avatar
i just flick the power switch off and on then set the new focal length.
06-12-2012, 01:51 PM   #6
tabl10s's Avatar
If you're using SR with an MF zoom, set the shutter speed to match the highest FL.
camera, change, dslr, k-5, k-5 ii, k-5 iis, k5, length, option, pentax k-5
Manual Focal lens length setting stevbike Pentax DSLR Discussion 21 04-02-2013 02:38 AM
Setting focal length with tele-converter chiggerbyt Troubleshooting and Beginner Help 2 02-04-2010 10:42 AM
setting focal length mc zenitar 16mm 2.8 fisheye lens into pentax k-x jheeno Troubleshooting and Beginner Help 2 01-05-2010 06:31 AM
setting manual lens focal length on K20 boyscout Troubleshooting and Beginner Help 9 05-01-2009 08:55 AM
Please help with setting focal length etc tomaplaw Pentax DSLR Discussion 6 02-02-2008 05:10 PM
All times are GMT -7. The time now is 07:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
