06-12-2012, 10:21 AM   #1
SMC-M 50mm 1,7
Hello everybody, I am delucky owner of a K-5 and I have also a SMC-M 50mm 1,7 lens witch Ilove the only problem is that I have to unlock by +- 10 degrees thelens to have my focus working isn t there an other way to have thefocus ring working,
Thanks for advising me
06-12-2012, 11:36 AM   #2
You mean that you have to dismount the lens in order to get it to focus? That doesn't make sense- could you please elaborate?
06-12-2012, 11:50 AM   #3
If I put the lens on, thefocus opens on maximum or 1,7, I can turn the focus ring but it staysom 1,7 full open, so if I want to go smaller I have to unlock thelens by +- 10 degrees and than it works, I can choose all the other Fstops,
06-12-2012, 12:14 PM   #4
pezmaker's Avatar
QuoteOriginally posted by FredWell Quote
You need to use it in M mode, or it will be stuck wide open. In M, you can meter and then adjust the shutter speed as desired. It will remain open while you're looking through and focusing, but the aperture will close down when you take a shot.
----- edit ----
WHen you're saying the focus ring opens on maximum of 1,7, i'm assuming you mean the aperture blades are staying wide open. If this is the case, than my advice above remains - you need to use M mode. If there is an issue with the focus ring on the far end of the lens when mounted, which doesn't seem to make sense, then I have no idea what the issue could be and I apologize for confusing the issue further.
If I'm correct in assuming you mean the aperture ring, then this should help guide you.
06-12-2012, 12:33 PM   #5
Yes Yes Yes !!! for the first time I took a look inthe lens (the front) and Yes it focuses thank You happy happy PentaxK-5 is a love story,
06-12-2012, 12:38 PM   #6
eddie1960's Avatar
these links will probably help you a bit Fred if you are going to use older manual lenses (the M 50 1.7 is a great start BTW)
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/49283-useful-pe...ces-about.html
https://www.pentaxforums.com/forums/pentax-beginners-corner-q/60081-usage-green-button.html
https://www.pentaxforums.com/forums/pentax-lens-articles/110657-how-use-meter...ml#post1987030
and an all purpose loads of links one that answers almost every question know to mankind
Have fun with the new lens
50mm, camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, smc-m, smc-m 50mm
For Sale - Sold: SMC A 35mm f/2.0 (Rare!), DA 40mm Ltd, Tamron 17-50mm f/2.8, SMC A 50mm f/1.7 leadfoot Sold Items 5 02-18-2012 12:19 AM
For Sale - Sold: K-mount Tamron-F 2x Pz-AF BBAR MC7 TC, TWO 50mm SMC-M F1.4, and a 50mm SMC-A F pxpaulx Sold Items 11 06-14-2010 07:42 AM
For Sale - Sold: SMC 50mm, SMC 50mm, Tokina RMC 28mm bri_n_m Sold Items 3 06-20-2009 12:27 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
