As mentioned above, you probably should do a “walk around” before even charging the camera and start shooting…as tempting as it is. As standard practice, whenever I receive deliveries of anything I order (both at home and at work), I usually inspect the package before even opening it; Is the info on packaging slip accurate, as in, is it what you ordered (i.e. body only, or body plus lens and other accessories), and is the package complete? Is there any shipping damage to your items?
If everything looks good and you have everything out, read the manual as most have suggested! If you’re up to a point where the camera is charged and ready for use, I would suggest checking as many functions as your knowledge can; are the camera’s basic functions behaving as it should per the instruction manual? Update your firmware as mentioned (Although be very careful with this procedure as it can render your camera useless if done incorrectly!) These may all be trivial but it would be better to know “now” if there is something potentially wrong with your equipment while under warranty.
Reformat SDHC Card - Technically, most brand new SDHC cards do not need reformatting however; it is highly recommended to format your new memory card in-camera and let it recreate its own file system/folders/directories “to its liking”.
As for “generally better than others” settings, IMO there isn’t any; since different shooting conditions requires different setup. Shoot RAW or JPEG+RAW. I suppose “Auto-Mode” would be a safe bet but that would defeat the purpose of using such a capable cameras as the K-5.
Good luck and enjoy!
