07-04-2012, 02:02 AM   #16
Look for the Nikon SG-3IR accessory...
07-04-2012, 03:48 AM   #17
Schmidlapper's Avatar
That is one reason why people buy radio triggers even when they have optical trigger built in. They can buy cheap or expensive transmitter/receiver sets and use with manual flash units which are often cheaper, but more powerful. Some downsides for them are the additional cost of buying transmitter and receiver, also they loose the p-ttl function and will need to use either a flash meter or chimp the shot.
07-04-2012, 01:25 PM   #18
Col
Col's Avatar
Just a sad comment on my skills I've had a similar exposure problem but then found I hadn't actually selected wireless flash on the mode dial. Once selected its worked fine for me.
07-06-2012, 04:08 AM   #19
Timd's Avatar
QuoteOriginally posted by dlacouture Quote
I was going to add this too. Nikon permit you to put on a IR filter on the flash so the master / commander can still communicate with the slaves, but in IR only which does not contribute to the photo taken. Not sure if it is a Nikon thing or if all of them work this way. Come to think of it, the sensor on the slave flash is behind a dark red window, so it must be the red end at least.
camera, custom, dslr, flash, k-5, k-5 ii, k-5 iis, k5, menu, mode, onboard, option, pentax k-5
finding custom menu ? Andrew Crouch Pentax K-5 5 12-05-2011 11:37 PM
K-7 - [Custom] Menu 36 - SEL Question SaikouShadou Troubleshooting and Beginner Help 4 08-11-2011 07:51 AM
Suggestion Wiki as a Menu Item adr1an Site Suggestions and Help 3 07-30-2011 03:27 AM
P-TTL does not work correctly with K-5 and Metz 54MZ-4i gomazo55 Troubleshooting and Beginner Help 19 03-02-2011 08:26 AM
K-7 flash in Wireless mode. Doesn't work correctly? Edvinas Pentax DSLR Discussion 7 09-07-2010 06:14 PM
All times are GMT -7. The time now is 01:57 AM. | See also: NikonForums.com, part of our network of photo forums!
