07-04-2012, 02:49 AM   #1
Something in my K5 Body is moving
Hello,
in the body of my new K5 is something (it feels like a block inside is moving a little bit) when I'm turning the body in different directions. Anyone any ideas if this is ok? Camera is working fine so far.
Thanks
misterpi
07-04-2012, 02:55 AM   #2
boriscleto's Avatar
Standard answer number 1. Yes your camera is fine. It is just the sensor shake reduction system.
07-04-2012, 02:57 AM   #3
No worries, that's the sensor. It's normal. The SR system requires that the sensor is moveable, and it only powers up to keep the sensor in place when you take a shot. So when the camera is switched off or in idle state, the sensor can move freely within the bounds of the SR construction.
Wim
07-04-2012, 03:05 AM   #4
thank you!
07-04-2012, 03:06 AM   #5
iwillau's Avatar
It's even stronger in the K-7... caused me a lot of headache last year. I hadn't discovered Pentax forum then, would have saved me a lot of worry as the top answers are spot on...instead I went to the shop where I bought it from, they thought it was odd too, so took it to the 'camera doctor' (all covered under warranty) just to be told it's fine...
07-04-2012, 03:25 AM   #6
Weird. I've never noticed this in my K-5....
07-04-2012, 04:14 AM   #7
WightWalker's Avatar
QuoteOriginally posted by ENicolas Quote
Yep, I can assure it's likely to be there!
body, camera, dslr, k-5, k-5 ii, k-5 iis, k5, k5 body, pentax k-5
Moving from Canon to K5 Jim Olson Pentax SLR Lens Discussion 3 01-07-2011 06:05 AM
Nature Moving Fast WiseOx Post Your Photos! 4 09-03-2010 06:42 AM
Moving away from Pentax..? phuey Pentax DSLR Discussion 47 08-21-2010 08:46 PM
Landscape Moving Around in One Area Jimbo Post Your Photos! 15 07-19-2010 06:18 AM
K100 D - Something is moving inside the body bazin Pentax DSLR Discussion 9 12-25-2006 05:36 PM
All times are GMT -7. The time now is 05:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
