07-06-2012, 08:57 AM   #1
Question on using multiple exposures with the timer feature
So I want to use the multiple exposures with the delay. But I can't seem to figure out how to change the delay from the 10 second default. Also, it seems to only take one of the 3 or 5 exposures at a time. I would think it would delay a few seconds and then capture the whole set.
Is this a setting somewhere I need to adjust?
Thanks,
Javaslinger
07-06-2012, 10:30 AM   #2
bwDraco's Avatar
  • In the Drive Mode menu, under Self-timer, change the setting to 2 seconds, then select Exposure Bracketing with the Remote Control sub-mode. The behavior of the Self-timer sub-modes for the Exposure Bracketing and Mirror Lock-up Shooting modes is based on the setting for the main Self-timer mode.
  • Set custom function 9, One-Push Bracketing, to On.
I just tried it on my K-5 and it works for me. Quite oddly, though, the self-timer delay occurs for each shot in the bracketing sequence, rather than for the first shot only.
--DragonLord
07-06-2012, 12:52 PM   #3
Great! That get's me 2/3 of the way there.. though the rest of the issue seems to be in the design. It's not only odd but unfortunate that there is a delay for each shot. Exposure bracketing needs to be rapid!
Hmmm, I don't suppose Pentax is likely to release a firmware update for this issue...
07-06-2012, 01:17 PM   #4
It would seem this was discussed to death previously....
https://www.pentaxforums.com/forums/pentax-k-5/176619-k-5-exposure-bracketing...ond-timer.html
To sum up, with the 2 sec timer there is a delay between each shot even when using Option 9 - One push bracketing - presumably to reduce mirror flap shake.
With the 12 sec time, the shots are fire in a row with no delay.
07-06-2012, 01:45 PM   #5
bwDraco's Avatar
I guess this is [status-bydesign] as we call it on Stack Exchange.
--DragonLord
camera, delay, dslr, exposures, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Multiple exposures and bracketing voyager13 Troubleshooting and Beginner Help 32 05-09-2014 04:20 PM
Multiple exposures without the ghostly effects - how? and more to ask ! jpzk Photographic Technique 10 01-30-2012 08:31 PM
how to take multiple shots in self timer with pentax k-r JaneDoe08 Troubleshooting and Beginner Help 6 12-28-2011 06:42 PM
Multiple exposures; K-7 clyde Pentax DSLR Discussion 4 07-31-2011 10:21 PM
multiple shots with self-timer patricklgv Pentax K-5 4 07-06-2011 05:30 PM
All times are GMT -7. The time now is 11:25 PM. | See also: NikonForums.com, part of our network of photo forums!
