07-16-2012, 08:01 AM   #16
WightWalker's Avatar
The problem, for me, with the lugs on the K5 body, is that point contact is small & with a large lens, the weight of the body causes these to wear; notwithstanding this, the weight causes the camera to droop which is quite uncomfortable.
I tried the Blackrapid but found it unsuitable when wearing a backpac/rucksac & eventually settled on something that costs less than a fiver which uses the existing camera strap & tripod mount; it's the Strapmate available from 7dayshop.com - Online Store which helps to make carrying your equipment quicker to use and less of a strain.
07-16-2012, 01:36 PM   #17
CMG
Op/Tech Envy
Op/Tech Envy with Pro-Loop System.
07-16-2012, 07:26 PM   #18
guadua's Avatar
The Ape Case neoprene strap is super comfy and cheap.
07-22-2012, 05:54 AM   #19
Thanks for all the comments re straps
07-28-2012, 07:54 AM   #20
BlackRockBacon's Avatar
I have been loving my Black Rapid RS7...although I will say that using it with a camelbak ( or any backpack) is awkward and uncomfortable most of the time.
07-28-2012, 09:00 AM   #21
philippe's Avatar
I am using the original strap that came with the K5, but I modified it a little.
I removed the red embroidered text (yes, I did it my self) because I have the habit of winding the strap around my wrist, and I found that the embroidery was to thick and to stiff to do this with any comfort.
Now it is an all black and anonymous strap
07-28-2012, 11:03 AM   #22
LeDave's Avatar
QuoteOriginally posted by BlackRockBacon Quote
Is using a sling bag more relieving?
08-03-2012, 08:50 AM   #23
CMG
QuoteOriginally posted by crewl1 Quote
+1 - I like the OpTech system but instead use an Envy strap section as it is slimmer and just as comfy.
The nice thing about Op/Tech is that you can customize the system to your liking as the parts are all interchangeable.
OP/TECH USA Utility Strap - Sling
+1....
08-03-2012, 06:33 PM   #24
Opt-tech
+1 I have this system. All parts interchangeable. Very reasonable price. wrist strap, shoulder strap, shoulder harness, clips for the front straps of a full size backpack. All easily interchangeable.
08-03-2012, 09:06 PM   #25
QuoteOriginally posted by Bonobo Quote
i went with one of the cheaper versions: Op/Tech USA Utility Sling \.
+1 on the Op-Tech USA Strap Sling. Just got mines in last week and it takes a huge load of my neck.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Blackrapid R-Strap RS-4 stevewig Pentax Camera and Field Accessories 22 02-27-2011 01:20 AM
Strap for 67 j.scooter Pentax Medium Format 3 11-19-2010 05:01 AM
what do you think about this strap? 100dwes Pentax Camera and Field Accessories 3 09-02-2010 03:07 PM
Goodbye to neck strap; Hello Wye Strap!!! philbaum Pentax Camera and Field Accessories 42 08-12-2010 01:39 PM
Strap to replace standard strap Mann Pentax Camera and Field Accessories 14 06-03-2009 09:35 PM
All times are GMT -7. The time now is 03:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
