07-24-2012, 10:56 PM   #1
Newbie need advice
Honestly, I don't know where should I put this thread, on the flashlight discussion or in pentax K-5 discussion. Since I'm K-5 user and I'm looking for K-5 users also, I put this thread below Pentax K-5 sub forum.
Recently, I want to buy a flash for my K-5. Is there any suggestion for me? I'm just a noob in flash photography.
I don't mind if it is a full manual flash like Yongnuo. But when I'm browsing this forum, I found that YN560 has a bad compatibility with K-5. Even that problems has been solved, I don't have an electrical knowledge to follow the instructions.
I'm also heard that using other brand can also work but it turn to full manual flash. Is there anyone has that kind of experience?
Thank you.
07-24-2012, 11:16 PM   #2
RobA_Oz's Avatar
Hi hamrio (and welcome, if no-one's said that before)
I can highly recommend the Metz lineup. I have the Metz 48AF-1, which is now superseded by the 50AF-1, both of which are fairly popular with Pentax shooters. The advantage of the 48 and 50 Metz guns over the Pentax equivalent (the AF360), is that they have tilt and swivel heads, whereas the Pentax model only has tilt - you have to move up to the AF540, which is more expensive, for tilt and swivel.
Rob
07-24-2012, 11:44 PM   #3
QuoteOriginally posted by RobA_Oz Quote
This was the very reason I went to the AF540 from the AF360. However, the AF540 is reportedly being replaced by Pentax, so I think they've recently stopped making them and are selling the remaining stock. I've heard good things about the Metz but not used them, so unless you find a good deal on an AF540 I would think Metz would be a good choice right now.
07-25-2012, 01:06 AM   #4
Rob
Between Metz 48 and Metz 50, is the difference is significant? Is there any problem with K-5?
QuoteOriginally posted by DSims Quote
Yeah, I've heard metz is the best third party for pentax flashes. But I also want to know about other third party like sigma or cactus. Do you have any experience of them?
07-25-2012, 04:36 AM   #5
RobA_Oz's Avatar
QuoteOriginally posted by hamrio Quote
The Metz 50 is a bit more powerful than the 48. Other than that, I'm not sure of differences, but I seem to recall the 50 has a metal foot (I know the 48 has a plastic foot).
Metz has been my constant companion for the past 25 years, sorry (well, there might have been the odd other brand from time to time, too). Others will have to comment here.
07-25-2012, 09:08 AM   #6
Ahab's Avatar
I have the Sigma EF-530 DG ST and do not have any issue with it. Best bang for the buck. I understand the latest model is even better.
07-25-2012, 12:12 PM   #7
I use a 540FGZ and have no problems and the images are great, how ever the only down side is that it can take a bit too long to recharge (does anyone know if I can by buy battery holder to speed up the recharge)
07-25-2012, 12:24 PM   #8
LeDave's Avatar
QuoteOriginally posted by GeeBee1 Quote
I don't know if batteries voltage may help speeding up the process of the flashes recharge rate. But what batteries are you currently using right now? Try using a higher voltage battery.
07-25-2012, 12:42 PM   #9
I only have a ring flash but I have read many posts regarding flashes and as far as I learnt, AUTO mode is more reliable than PTTL, which is available only in the most expensive Metz and Pentax flashes or in some other brand flashes like Nikon SB, which you can buy used for around 100$.
Dear Pentaxians please correct me if I am wrong
07-25-2012, 08:30 PM   #10
Is this what you're referring to? Pentax TR Power Pack III 37225 B&H Photo Video
However, before you try that, make sure you've at least tried the best Energizer Lithium AAs in the flash first. If it's still too slow, then try the Power Pack if you like. The guy I got my AF540 from had one, but I only purchased the flash and a lens from him.
07-25-2012, 08:35 PM   #11
I realize this isn't a complete answer, but the bottom line is that Metz makes flashes for some of the big guys, and for all we know they could end up making the AF540 replacement anyway. So even though I like my AF540, I'll probably being looking at Metz first next time, unless Pentax has a compelling new model.
07-27-2012, 08:02 AM   #12
I see. There isn't a big difference then. I heard that Metz 48 is already discontinued. It is hard to find it right now.
QuoteOriginally posted by Ahab Quote
For newbie like me, the old model is not a problem. As long as it works well, It can be a tool for me to learn about flashes and lighting.
Yeah. Pentax must think about flashes also in their further development.
07-27-2012, 10:29 AM   #13
I use Sanyo but last night i tested the flash gun again, I do not know what \i did but I was able to do multiple flashes, At least I am now happy hehehehe'
Thanks
Gary
07-27-2012, 10:31 AM   #14
QuoteOriginally posted by LeDave Quote
Thanks
camera, discussion, dslr, flash, forum, k-5, k-5 ii, k-5 iis, k5, pentax, pentax k-5, thread
Thinking about a K-r after a little Newbie advice skankin_giant Pentax K-r 38 03-16-2012 01:36 PM
Equipment advice for a Newbie awrauch Troubleshooting and Beginner Help 16 03-02-2012 11:03 AM
Newbie looking for lens advice. Damon Troubleshooting and Beginner Help 27 01-28-2012 04:34 AM
Newbie wants advice trent84 Pentax SLR Lens Discussion 10 06-12-2011 09:31 AM
Newbie seeking advice gramar Pentax SLR Lens Discussion 9 03-18-2011 03:15 PM
All times are GMT -7. The time now is 08:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
