07-25-2012, 08:46 AM   #1
moving object: do i use TV setting
There is a cute fox like dog come to my office tomorrow monring. I want to use my new K5 to shoot several pictures. Do I use TV setting. If I do, do I also need to set MF instead of AF? Thanks.
07-25-2012, 08:55 AM   #2
Don't worry about manual focus, but you'll probably want a faster shutter speed, which you can set in Tv mode or in P by turning the front e-dial. You could also set the program line to action so that the camera will choose a faster shutter speed by default.
07-25-2012, 08:56 AM   #3
Lowell Goudge's Avatar
more details would be of use. what lens, what lighting conditions , indoors, outdoors, etc. will the dog be running, or walking etc....
to get a sharp image, you need to consider all these things. Since you are talking about moving subjects, lets start by assuming no shake reduction, therefore to remove camera shake, and assuming you are considering the whole frame, and not cropping in, your first limit is
shutter speed = 1 / ( focal lentgh x 1.5 )
then, you may also need to consider, for a slow moving subject, something in the order of 1/200 to freeze the image. If he is running full out, and you are panning with a shutter speed in the 1/200 the main body will be OK, but the legs could be blurred. Higher shutter speed would freeze the legs too
07-25-2012, 06:14 PM   #4
Hi all:
Thanks for your quick response. My lense is smc pentax DA 18-135. The following is my further question
Adam:
So I am still in AFS? When I TV, and set speed, I found the aperture F is shinning. i guess it means my camera is under exposure. What should I do? Increase ISO?
Lowell:
is the formula the slowest shutter speed I should have? Why?
07-26-2012, 01:01 AM   #5
When shutter speed is important (mainly due to catching fast moving objects) I always use TAv mode. I set the desired shutter speed to freeze the object and aperture for desired DOF, then camera takes care of ISO for proper exposure.
07-26-2012, 06:42 PM   #6
Hi, all
I believe I figured out most after reading thoroughly the menu book and comments from this thread. I will use P, AV or TV based on the situation. But still have a small doubt: how do I use MF?
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, setting, tv
CS5 bridge Merge To HDR Pro smart object option? Deiberson Digital Processing, Software, and Printing 8 03-27-2012 10:09 AM
O-GPS1 - How is this works with moving + stationary object? LFLee Pentax Camera and Field Accessories 12 09-30-2011 12:42 PM
Algorithm for identifying object boundaries in digital images 50,000 times more effic Scottie137 Digital Processing, Software, and Printing 2 06-02-2011 09:26 AM
Nature flying object balunz Post Your Photos! 4 04-29-2011 10:09 PM
All times are GMT -7. The time now is 10:01 AM. | See also: NikonForums.com, part of our network of photo forums!
