08-01-2012, 03:54 AM   #1
My K5's outer rubber is peeling away
Just from the right side of front wheel. Rubber is little loose (about 1cm lenght now) and starting to peeling away little by little. I did buy my K5 in February 2012 and about 12000 pics taken. Some people here say that K5 is build like tank but even i have kept my K5 always nicely still start to broken already. Anyone else noticed same peeling as me?
08-01-2012, 06:16 AM - 1 Like   #2
The grip sections on all of the Pentax DSLR's I've had are completely attached by simple double sided tape. For the K-5, one side has a screw under it, so don't try gluing it to the camera because that would be a problem when trying to service the camera. If the grip material somehow won't form to the body anymore, you could buy some replacements from Pentax, or your could try re-taping your existing grip material.
08-01-2012, 09:54 PM   #3
Thank u for ur advice, i was planning to try glue, but i will try double sided tape instead tnx to U
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, rubber
Outer Bay Tubes desertscape Pentax Medium Format 2 06-20-2012 01:12 AM
Abstract It's not from outer space Den Post Your Photos! 2 03-02-2012 08:06 AM
Peeling Birch foto guy Monthly Photo Contests 0 09-25-2011 02:12 PM
Liquid on lens outer ring jasonbx Troubleshooting and Beginner Help 3 01-24-2010 11:54 AM
Stockholm outer skerries Haakan Post Your Photos! 12 08-02-2009 09:30 PM
All times are GMT -7. The time now is 08:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
