08-03-2012, 12:20 PM   #1
UpNorth's Avatar
"One-push" setting of shake reduction.....
I've just spent about 15 minutes with the manual - and I haven't come up with anything, so I thought I'd see if anyone here has run across this.
Is there a way to make turning on/off the Shake Reduction function a "one-push" kind of process? I'd like to assign that function to a button or dial so that I don't have to dig through the menu for it when I'm switching back and forth between long and short lenses, but I can't find anything in the manual about setting that up.
Thanks in advance for any help.....
Tim
08-03-2012, 12:28 PM   #2
JinDesu's Avatar
QuoteOriginally posted by UpNorth Quote
Tim
Could always set the bracketing mode to Wireless Remote - it's three pushes or so (just go into bracketing menu). It automatically turns off SR and you can still fire it from the shutter as normal.
08-03-2012, 12:58 PM   #3
I know it's not one-push, so not quite what you are after.... But for me the quickest way for a few settings is via the settings screen that can be accessed through the "Info" button. SR can be controlled from here.
I just checked, and can toggle SR in two moves that way....
08-03-2012, 01:21 PM   #4
UpNorth's Avatar
QuoteOriginally posted by JinDesu Quote
Makes sense - Thanks Jin.....
08-03-2012, 01:22 PM   #5
UpNorth's Avatar
QuoteOriginally posted by jcb1973 Quote
I'll give it a shot tonight and see. Thaks jcb!
08-03-2012, 10:20 PM   #6
I use the info button regularly. Quick and easy. I also have user modes set up with among other things, SR off or on depending on the mode.
08-04-2012, 02:16 AM   #7
abmj's Avatar
Ditto on the Info button. Eliminates the need to go into a menu.
camera, dslr, function, k-5, k-5 ii, k-5 iis, k5, pentax k-5, shake
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
Using "stops" to measure Shake Reduction sydbarett Photographic Technique 23 07-02-2012 08:43 AM
Question about Ilford 3200 and "push process" Todd Adamson Film Processing, Scanning, and Darkroom 5 03-28-2011 06:00 AM
Suggestion Can we add a setting to control the size of "Latest threads in which you've post"? Laurentiu Cristofor Site Suggestions and Help 2 11-21-2010 12:43 AM
shake reduction + "panning" nanok Pentax DSLR Discussion 38 05-25-2009 08:49 AM
All times are GMT -7. The time now is 08:55 AM. | See also: NikonForums.com, part of our network of photo forums!
