08-15-2012, 04:26 AM   #1
Histogram in display of K5
I have not used my K5 for a month because I recently bought the K30 but today I took both out and notice the histogram in the K5 had a bar graph look to it. I can't remember if the histogram was like this before. I am not sure but this usually happens if some information is missing or if a file is posturised. My first thought was that the sd card was currupt so I changed it but the result was just the same. Could it be the sensor or faulty in camera image processing.
08-15-2012, 11:38 AM   #2
donras's Avatar
Not sure exactly what you're seeing, but the histogram is composed of vertical bar across the range of light intensity. Adjacent bars have no space between them, so if adjacent light intensities are similar, the graph will look fairly smooth. Where light intensity differs markedly at one level from its adjacent levels (bars), that bar will either stick out or be depressed from the others, giving a notably jagged look.
I know of no settings, and no real-world scenes, that would produce a large number of adjacent bars that alternate from zero to some positive value. High contrast, and sometimes sharpening, can produce this look in some image processing programs, but I've never seen it on the K-5.
Don
08-16-2012, 02:49 AM   #3
Thanks for your reply. Since posting I looked on the internet and found that it is commonly known as the comb effect. My understanding, limited, is that if the comb effect came from the base of the histogram with gaps between each bar then information is missing but my the comb effect in my histograms extended from the peaks and troughs which apparently is perfectly normal and dependent on the scene photographed.
08-16-2012, 02:49 AM   #4
Banned
Got pics?
camera, dslr, histogram, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Histogram Patajac Digital Processing, Software, and Printing 6 06-05-2012 09:56 PM
K-5 Histogram? geekette Pentax K-5 9 05-18-2012 10:27 AM
Histogram Mapleleaf-Mick Pentax K-5 5 08-25-2011 06:14 AM
Using the histogram on K5 njpentax Pentax K-5 24 08-15-2011 05:33 PM
K10D histogram display jjfdvm72 Pentax DSLR Discussion 3 12-15-2007 08:44 PM
All times are GMT -7. The time now is 08:15 AM. | See also: NikonForums.com, part of our network of photo forums!
