08-16-2012, 08:29 AM   #1
EV St0ps - 1/2 or 1/3 and why?
Do you set your K-5 EV stops at 1/2 or 1/3 and do you match your ISO? Taking flash timing issues out of the discussion, which EV stops do you set and why?
08-16-2012, 08:35 AM   #2
builttospill's Avatar
I set my K10D's EV steps to 1/3 for more flexibility in correctly exposing an image, especially when I want to use a wider aperture in the late evening as the sun is setting and I'm losing light.
As far as flash timing goes you lose 1/180 with 1/3 EV steps in M and Av modes, but there's not much difference between 1/180 and 1/160. If I really need 1/180 I set the dial to "X" and keep 1/3 EV steps.
08-16-2012, 08:36 AM   #3
jatrax's Avatar
I use 1/2 stops. If I cannot get it close enough with a 1/2 stop 1/3 stop is not going to help. When shooting RAW there is more than enough flexibility to adjust the exposure a bit if I did miss.
I think 1/3 is too complicated, I have enough trouble remembering the 1/2 stops........
08-16-2012, 08:42 AM   #4
This topic was discussed some over in this thread: https://www.pentaxforums.com/forums/pentax-beginners-corner-q/191915-1-2-1-3-exposure-value.html
Mostly, I keep my EV stops for shutter and aperture at 1/2 because it seems easier to me. Lately, I've been trying out having the ISO in whole stops. I'm not sure yet if I prefer this set up or not. I might return to having everything set at 1/2 stops. I'm just not picky enough with my exposure fiddling to need 1/3 stops except for possibly in very rare circumstances. I'd like to observe a little more closely how the choice between the two affects the semi-auto exposure modes. Maybe that would fit into someone's equation for making their decision.
QuoteOriginally posted by CMG Quote
Well, falling on the max flash sync of 1/180 does fit into my equation for why I like using the 1/2 stops.
08-16-2012, 08:55 AM   #5
I am a 1/3 kind of guy. I just like the extra fine tuning as I shoot jpeg and do no post photo, unless it is for a client or "gallery worthy photo"
08-16-2012, 09:00 AM   #6
Anvh's Avatar
1/3th for me as well, simply reason is that im used to that. these days there is more hen enough leeway to use 1/2th so in a way that is faster.
08-16-2012, 09:04 AM   #7
CMG
QuoteOriginally posted by calculator01 Quote
I shoot JPEG as well so I appreciate your perspective on this issue. I try to get my exposures correct and do minimal PP. I guess the related question is how much finer is the fine tuning when you go from 1/2 stops to 1/3 stops. Is it "real" or is it a "bell and whistle" feature to market the camera? Or was it developed really for use in auto-modes? I mean, as I understand it, in the old film days it was all 1/2 stops.
08-16-2012, 09:32 AM   #8
Hi CMG,
I shoot jpegs and use EV comp probably more than most since I shoot birds in very varied settings as they appear, I often need to adjust EV comp from shot to shot. Though 1/2 stop is quicker, I have settled on 1/3 stop as it is a bit more precise, and I get overall better results for my jpegs with the greater precision.
Each to his own though -- that's why there's a choice. If I shot RAW more, I'd probably fo to 1/2 stops to make it easier since I'd have more DR to work with.
Scott
08-16-2012, 09:41 AM   #9
dms
1/3 e.v. (stop) gives you more control, 1/2 is faster--gives you greater range (on K20D anyway).
If coming from film--film iso was rated every 1/3 e.v. (e.g., iso 100, 125, 160, 200) while lens aperture was often 1/2 stops, or could be estimated at 1/2 stop--by placing ring midway.
If you don't use it much--need to ask--I suggest 1/2 e.v. is a good start.
08-16-2012, 09:43 AM   #10
Until they have 1/4 EV stops I won't be satisfied! Actually, I'd probably be more comfortable with that than 1/3 as I could still hit 1/2 stops, despite the loss in speed it would create for scrolling through the values. My guess is that while 1/4 stops wouldn't present any problem for the shutter speed or ISO, it could be difficult to have the aperture hit that value accurately.
08-16-2012, 09:51 AM   #11
thanks for the post, something else to think about.
08-16-2012, 10:04 AM   #12
CMG
QuoteOriginally posted by dms Quote
Can you explain a bit more for me how 1/2 gives you greater range? I see how it is faster because there are less steps to a full stop, but I'm not sure about the greater range part. Thanks!
08-16-2012, 10:07 AM   #13
CMG
QuoteOriginally posted by TomTextura Quote
This is an interesting point....can you explain a bit more? It's funny, but until I read your post, I had not realized the fact that in 1/3 steps you can't hit a 1/2 stop. I suppose, I'm wondering about the significance of that and how it impacts exposure vs 1/3 steps. I understand that a full stop is a full stop, it's a question of whether you get there in 2 steps or 3...but is there more to the story?
08-16-2012, 10:23 AM   #14
dms
greater range of adjustment on (K20D). +/- 6 e.v. stops --> +/- 3 stop vs +/- 2 stops for 1/2 and 1/3 e.x. steps respectively
08-16-2012, 10:25 AM   #15
CMG
..Huh?
camera, dslr, ev, k-5, k-5 ii, k-5 iis, k5, pentax k-5
All times are GMT -7. The time now is 12:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
