08-27-2012, 01:47 PM   #1
K-5/Transcend SD Card Puzzler
Last evening I shot a number of night sky frames with my K-5, loaded with a 32 gig Transcend SD card. I reviewed the images before calling it a night(morning). Later this morning when I turned on the camera to have a look at the frames, they were missing. I then shot some additional test frames that I could recall while the camera was turned on but when I turned it off and back on, and tried to bring up the test frames, they were also missing.
I then loaded a 16 gig Transcend card and ran the same tests. I didn't lose the test frames with the 16 gig card. The particular 32 gig card that lost the frames also has files on it from my 645d as well as some old Canon files, FWIW. Does anyone have any ideas? Thanks for any thoughts.
Additional note: The offending card has space for over 400 K-5 RAW files remaining, so I'm sure it's likely not a memory space issue.
08-27-2012, 02:01 PM   #2
Docrwm's Avatar
What firmware version are you using in your K-5? I seem to recall that older firmware had a problem with higher gb cards.
08-27-2012, 03:26 PM   #3
QuoteOriginally posted by CDW Quote
Never mix and match a card between cameras, especially between different brands. The manual warns of this.
I've seen similar things happen when using the same SD card on either my NEX or my Fuji point and shoot with my K-x. It seems safest to format cards in-camera, and use one card with one camera type.
08-27-2012, 09:26 PM   #4
abmj's Avatar
Agree with the above. It sounds like the card is formatted for a different camera - perhaps a Canon? I'd suggest pulling everything off the card to your computer and reformatting in whichever camera you will be using it in. Don't mix and match.
08-28-2012, 06:25 PM   #5
CDW
Thanks all, good points and I actually remember being told in the past to format the card for the camera. Over the last few years I've mixed cameras/cards without formatting and this is the first time it's been a problem. Lesson learned!
camera, card, dslr, frames, k-5, k-5 ii, k-5 iis, k5, missing, pentax k-5, space, test
For Sale - Sold: Transcend 8GB class 4 memory card *NIB* (US) Ubuntu_user Sold Items 0 11-10-2010 11:26 AM
For Sale - Sold: transcend 16gb sd card (CONUS) shimoyjk Sold Items 3 08-31-2010 06:12 PM
Transcend 8GB microSDHC Card - Class 6 Fl_Gulfer Pentax Camera and Field Accessories 23 01-12-2009 07:57 PM
For Sale - Sold: FS - Transcend 2GB SD Card x150 Genes Pentax Sold Items 4 04-27-2008 09:48 PM
Transcend 4Gb 150X SD Card - $34.99 shipped Teja Pentax Camera and Field Accessories 3 04-14-2007 10:10 PM
All times are GMT -7. The time now is 10:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
