Hello fellow pentax users!
I have an issue with my K-5 that can't seem to be fixed. Upon switching on the camera, sometimes the sensor locks itself in a crooked position and so all the pictures are significantly crooked. This happens randomly, about 30% of the time. I have seen this forum someone with a K-7 that had the same problem (even posted a picture of the angled sensor here:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/66210-k-7-crooked-sensor.html). Attached are two photos showing the problem using a 8mm lens and one photo using a 55mm lens. Unfortunately I was unable to photograph the crooked sensor before sending the camera off for servicing.
When the sensor locks in the correct position, the pictures come out fine. But, this only happens 70% of the time. So basically I am forced to switch on the camera in live view to see if the sensor is in the correct position.
Has anyone had this problem? How was it fixed, if it is fixable?
Cheers!
