10-18-2012, 04:10 AM   #46
the color moire is indeed easy to fix, what troubles me is the band? pattern? moire, if you take a close look at the bottom left of the feather miles posted,you can clearly see the band moire not removed, thats the information lost right from the sensor...
where are the k5iis samples !?!?!?! aaahhh i cant wait to see them..
btw i have somewhere a photo taken with my k-5 with moire and everything, using, wait for it... the kit 18-55wr lens ... and it's band moire pattern on fabric not severe but its there...(it'll take some time to find it and post it, lost in the chaos of my external drive)
as someone said in this forum(not exact words),if you try hard you can get moire with the k5, but is it something you have to try hard to avoid with the k5iis?
last but not least... band moire on fabric using the d800e, or in other words, what we want to avoid...
found the image googling d800e moire
source according to metadata is http://www.silkyfoto.com
10-18-2012, 04:41 AM   #47
JohnBee's Avatar
QuoteOriginally posted by miles Quote
Moire: no big deal. Surely it's even easier to remove from a raw file. Software will soon be better at identifying it, since going AA-less looks like where we're heading (see recent Pentax interview).
I just edited this pic posted here in under one minute using the gimp... With other examples i've seen, C1 pro makes it disappear with its moire tool (2 sliders).
original / no moire
Most impressive.
10-18-2012, 05:43 AM   #48
RonHendriks1966's Avatar
QuoteOriginally posted by obscura Quote
source according to metadata is Silky33 page
It is nicely accentuating the curves, but you don't want this for any serious pictures when producing pictures for clothes as advertisement.
10-24-2012, 01:09 AM   #49
Class A's Avatar
FWIW, I wrote a small article on the "Pros and Cons of Omitting an AA-filter".
10-24-2012, 08:11 AM   #50
QuoteOriginally posted by RonHendriks1966 Quote
I agree.
I've also seen it in clothes ads, disappointingly.
10-29-2012, 06:32 PM   #51
QuoteOriginally posted by aT0Mx Quote
More, for something they don't have to install? odd.
Anti-Aliasing filter.
Anti-aliasing filter - Wikipedia, the free encyclopedia
I too am wondering why the IIs with less hardware and less installation effort is $100 higher rather than lower than the II. This seems to be a great idea for landscape shooters, but paying more for less seems to be a ripoff. Has Pentax commented on the reason for the price differential?
10-29-2012, 07:19 PM   #52
Class A's Avatar
QuoteOriginally posted by glennm Quote
The filter layers in front of the sensor are more complicated than you probably think.
Have a look at this image of the Canon 30D layers.
It isn't just a matter of omitting a part. Note that the AA-filter consists of three layers which are not adjacent to each other.
Removing the AA-filter either means replacing the layers with something else (Nikon's D800e uses two layers which aren't inactive, but cancel each other out) or having to perform different calibrations depending on the camera model.
All the above complicate mass production and it only makes sense for the variant that is produced in lower quantities to command a small extra.
10-29-2012, 07:40 PM   #53
It all depends on the application
If you are shooting wide landscapes then the filterless K-5IIs will give you a sharper and more detailed image to work with in RAW. If you are shooting seascapes or other water-related scenes it should also work well.
Any fine and repetitive detail can cause moire patterns - generally not a problem with 'scapes. If you're doing product or portrait or (like people have demonstrated) birds you may see some problems. And not all moire can be handled in software.
So if you are shooting for multiple purposes you should have an AA filter or you should have two cameras to work with. I'm personally thinking about getting a K-5IIs to go with my original K-5.
But the comparison shots just published here in the K-5II/s review have sold me on the effectiveness of no AA filter for landscape shooting: Pentax K-5 II / IIs Review - Introduction - PentaxForums.com
10-29-2012, 09:52 PM   #54
QuoteOriginally posted by JohnBee Quote
It only takes one bird to regret it
I saw a feather shot with a D800 and it had it. So as a birder I will pass.
Hoping the next round will bring a better camera for birders.
Sitting this one out with high hopes for the next round.
camera, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5
Will K-5II/IIs firmware work for K-5 Classic? LIJ Pentax K-5 18 11-04-2012 09:16 AM
Pentax K-5 II and K-5 IIs OFFICIALLY Announced Adam Pentax K-5 9 09-11-2012 08:43 AM
Oops, I moved the sliding thing with plus and minus behind the eyecup... What is it? Student Pentax DSLR Discussion 14 02-21-2011 02:52 PM
Variable ND Filter - Fader ND mark II yusuf Pentax SLR Lens Discussion 2 11-16-2010 11:39 AM
K-7 kit minus the K-7 mel Pentax DSLR Discussion 4 08-17-2009 07:38 AM
All times are GMT -7. The time now is 10:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
