09-10-2012, 06:26 PM   #1
Glen's Avatar
K-5 starts with Firmware Screen
Lately when I turn my K-5 on the screen at the back is the one you should only see if you are holding down the menu button when turning on the power. I is the basic screen that says what version of firmware is loaded. It started while I was on vacation and then just periodically. Now it is doing it more often and does so regardless of the lens in use. Is this a known problem? Is there a solution? It is still under warranty but if there is a quick fix I would sure prefer that. Oh and I did download the latest firmware again and installed it but that made no difference.
09-10-2012, 06:32 PM   #2
Do you still have the firmware file on your card? If so, delete it just as a precaution.
09-10-2012, 07:39 PM   #3
Glen's Avatar
Good suggestion but I reformated the card right away so that should take care of it. The only thing that I can think of is that the menu button may be sticking causing the wrong screen to come up on start up.
09-18-2012, 06:17 PM   #4
Glen's Avatar
My K-5 started getting worse. Not only would the firmware screen come up intermittently on start-up, but the menu would come on without pushing the menu button and go off the same way. In playback mode if I move the camera the menu would come on. It went back to the dealer (I'm glad I bought local this time) and hopefully I'll have it back before Christmas. So much for autumn images.
10-05-2012, 02:49 PM   #5
Glen's Avatar
It's back. Less than three weeks for servicing across the country. Not bad. So far it appears okay as they just said they tightened something. That makes sense so I suppose something was loose inside that affected the ability of the camera rear buttons to function properly.
I recall when I bought it the store manager said that while he sells a lot more Canon and Nikon, Pentax has the quickest turnaound time for repairs. He must be right.
camera, dslr, firmware, k-5, k-5 ii, k-5 iis, k5, pentax k-5, screen
People It Always Starts With Pizza... Rupert Photo Critique 15 05-19-2011 12:01 PM
Revolution starts in WI jeffkrol General Talk 3 04-22-2011 12:46 PM
One who starts with Pentax... indranama Welcomes and Introductions 3 04-15-2011 08:43 PM
Landscape Fonblanca, the spring that starts it all gfonso Post Your Photos! 13 11-03-2010 04:48 PM
K-7 starts then immediately turns off wjax Pentax DSLR Discussion 9 09-19-2010 03:47 PM
All times are GMT -7. The time now is 01:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
