09-10-2012, 09:00 PM   #1
fanofcc's Avatar
Metering on K5 + M42 lens
Hi all .
I just bought a K5 and have only 2 lens M42: Super Takumar 50 f1.4, SMC Takumar 135 f2.5. When i use the M42 lens and push Green button, i don't see metering bar??? I wonder if it is normal
Anyone used K5 with M42 lens please tell me. Did you see metering bar when use K5 with a M42 lens?
Sorry for my bad English
09-10-2012, 09:26 PM   #2
arnold's Avatar
First decide on your aperture. Then push the green button, and you will see the speed in the lower left corner of the view finder. You may have to manually close the aperture to get the reading on an older lens. If you don't like the speed, change the aperture and repeat
09-11-2012, 01:02 AM   #3
Another way is to set the camera in av mode. It will then automaticly set the shutterspeed when you set the aperture.
Anyway, I will recommend focusing wide open and then stop down.
09-11-2012, 01:32 AM   #4
fanofcc's Avatar
Thanks . I use M mode, i'll try Av mode when i come home
Maybe cause my bad English. I wonder about metering bar, which appear on my old Canon EOS when half press shutter button
09-11-2012, 01:52 AM   #5
There is no metering bar with m42 lenses
09-11-2012, 02:04 AM   #6
fanofcc's Avatar
Thanks, Hyper
camera, dslr, k-5, k-5 ii, k-5 iis, k5, lens, m42, pentax k-5, takumar
I got multi-segment metering on an M42 lens--how?! MobiusOne Pentax DSLR Discussion 15 11-29-2011 08:45 AM
Mirror flopping when metering w/ green button and old m42 lens Philoslothical Troubleshooting and Beginner Help 15 10-22-2011 05:06 PM
Questions about using M42 lenses - focus and metering Spodeworld Troubleshooting and Beginner Help 23 10-12-2011 10:01 AM
Mounting and metering a Helios M42 hcarvalhoalves Pentax SLR Lens Discussion 7 05-31-2011 08:56 PM
M42 lens metering differently in liveview vs viewfinder sameagle Troubleshooting and Beginner Help 15 09-07-2010 07:11 AM
All times are GMT -7. The time now is 12:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
