Originally posted by Javaslinger A friend's jewelry is being featured in a local mag and she's asked me to shoot it.. I've got a Pentax K5 with a new (used) Tarmon SP 90mm macro (1:2.5) and some extension tubes and a 2x teleconverter (7 elements) which I think some combo of would be nice for it...
Advice on how to do this? Where do do it? Lighting?
I'm a rookie enthusiast...
Thanks!
Ken
This is always a bit of fun..
Personally I prefer to shoot things like jewelry on white or black backgrounds to give added contrast to the object I just used an A3-A2 sheet of paper and curve it up behind to create that infinity wall look. Camera settings; I tend to use either my
Tamron SP AF 90mm F2.8 Di or my Sigma EX 105mm F2.8 Macro @ 1/125 ISO 100 and F5.6-11 depending on needed depth of field. I use 1/125 instead of 1/180 due to my wireless triggers (
2X Yongnuo RF602's) having a bit of lag in them and catch the shutter closing at shutter speeds above that. As for lighting I use 2 off camera strobes
(Yongnuo 560 + Metz 58AF-2) with diffusers to get a more even light, ie at a 45 degree angle either side of the camera.
Here is the type of results you can achieve with that sort of set up:
Edit: most of the lighting stuff I got off ebay:
Yongnuo flash: $70 (My metz was from B&H @ $300 but I use it as hotshoe flash most of the time for events as the yongnuo lacks features for that stuff)
Radio Trigger: $30
Umbrellas 33": $4each
Light stands: $6-10 each
Edit #2:
You could also try firing a strobe from underneath to reduce the shadows cast, but this requires a 3rd strobe to ensure even lighting.
