09-17-2012, 06:49 PM   #1
Too large focus point issue?
Hi All,
I am having issues with focus. I am using the FA 35mm 2.0 lens on the Pentax k-5. When shooting a subject relatively close, the focus is spot on, but from a distance it misses almost every time. So is this a too large focus point issue that I have heard about? If so what can I do to increase my success rate of an in-focus image from a distance. I mainly shoot pets so I need to focus quickly and shoot. See the examples below:
All were taken at:
ISO 800
f 2.0
Shutter 1/500
Center focus
All photos focused on the flower in the center
1209_focus_problems_003 | Flickr - Photo Sharing!
1209_focus_problems_001 | Flickr - Photo Sharing!
1209_focus_problems_002 | Flickr - Photo Sharing!
09-17-2012, 06:51 PM   #2
JinDesu's Avatar
It appears so. That last shot definitely seems like the camera's center point decided the background green was more contrasty.
You CAN try another trick though - shift the center point around to see if it does anything. Sometimes my k-x's center point wants to focus on the rear stuff, but if I adjust my center point to get two legs of the + to cover the subject, it will focus.
09-17-2012, 07:03 PM   #3
Can you see what is in focus in the viewfinder when you are shooting? With such a busy scene, moving the composition slightly one way or the other will change what is in focus. If you can't see it however, you can't select the one you want.
I used my 170-500 lens this weekend shooting small birds in the bushes. I had a stable platform, a monopod with gimbal, so I could keep the aim steady. I was able to focus on small birds between branches by changing the composition slightly and depressing the shutter button halfway. I think the difference may be the focus screen; I could see clearly what was in focus or not.
09-17-2012, 07:15 PM   #4
Liveview really helps solve this problem.
camera, center, distance, dslr, flickr, focus, k-5, k-5 ii, k-5 iis, k5, pentax k-5, photo
Macro focus stacking + large numbers of frames v5planet Photographic Technique 7 01-29-2012 02:59 PM
Large back focus on a new lens adwb Pentax K-5 2 11-02-2011 09:56 AM
Large manual focus lens focal stability ghillindy1 Pentax DSLR Discussion 8 11-26-2010 10:49 AM
K-X 11-point Auto Focus issue Matte Black Pentax DSLR Discussion 67 04-09-2010 12:55 PM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
All times are GMT -7. The time now is 07:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
