09-18-2012, 01:19 AM   #1
i83N's Avatar
HDMI out question
Dose K-5 live output sound though HDMI output? (same about K-01)
I want to try using this Atomos Ninja 2 - HDMI Field Recorder, Monitor, Playback & Playout Device with K-5 to record video.
09-18-2012, 09:21 AM   #2
Anvh's Avatar
The video it send out is so far as i know not a clean source.
09-18-2012, 10:40 AM   #3
RonHendriks1966's Avatar
The output is limited. So the use fot this device is very limited.
09-18-2012, 01:36 PM   #4
i83N's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
sad :/
09-19-2012, 09:13 AM   #5
Anvh's Avatar
Only DSLR useful would be the Nikon D800 and maybe the D600, for the rest it's all the same as pentax.
09-19-2012, 09:34 AM   #6
LaurenOE's Avatar
The K5 output is not "clean" but it's great output. I don't think anyone should equate "clean" with bad/good. The HDMI output works very well and I use it all the time with an external monitor.
09-19-2012, 09:35 AM   #7
LaurenOE's Avatar
The Zacuto folks even updated their firmware to deal with the K5, but for the most part, there are few problems with it - hence - no need for the "clean" output of other manufacturers.
09-19-2012, 11:34 AM   #8
Anvh's Avatar
Lauren you're missing the point, i83N wants to record the HDMI stream.
So yes clean is important then!
09-19-2012, 11:46 AM   #9
LaurenOE's Avatar
QuoteOriginally posted by Anvh Quote
The HDMI stream is a little different than monitoring it - kinda like RAW vs. JPEG, so I understand.
However, I have never been able to get too much recording time due to heating issues and the limitation on file size.
So the only *real* benefit of a device like the above is to bypass the file size of the camera and to record directly to external media.
Even with that benefit, I'm not sure how heating issues are a factor and working with HUGE files is not that much fun to begin with.
Then, if there is any compression in the above device, then the benefit of the RAW HDMI stream just went out the window!
My video workflow with the K5 is to work with TWO K5s, and to keep my clips very short.
The device above is very nice no doubt and it would be great to get the HDMI stream. No argument there. However, it's not a deal or workflow breaker when using the K5.
09-19-2012, 12:19 PM   #10
Anvh's Avatar
I don't doubt you understand it but i do believe you missed that part of the question when you said that clean wasnt important
The D800 has clean uncompressed HDMI output so you get better quality file and i thought to have read that the D600 has it as well.
this with the recorder the OP wants to use.
http://fstoppers.com/fstoppers-review-atomos-ninja-external-recorder-with-nikon-d800
So like you said, will this be a show stopper?
camera, dslr, hdmi, k-5, k-5 ii, k-5 iis, k5, output, pentax k-5
HDMI-output from K-5 and K-7 to a Field Monitor. RonHendriks1966 Pentax Camera and Field Accessories 6 10-16-2013 02:13 PM
K-01's HDMI output pundit Pentax K-01 2 03-17-2012 04:51 PM
hdmi out? Anvh Video and Pentax HDSLRs 3 12-06-2011 04:02 PM
HDMI Out Port soppy Pentax K-5 15 12-13-2010 01:02 PM
HDMI cable for Pentax K-7 tjom General Talk 9 10-27-2010 05:07 PM
All times are GMT -7. The time now is 05:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
